LUMINTOP GT98 8x SBT90.2 LED 43000lm 2500m Thrower Flood Flashlight - $349.99 OFF!!!
Specifications
Emitter: 8x Luminus SBT90.2 LED , mounted on copper DTP MCPCB
Flux: >43,000 lm
Intensity: >1563 kcd (ANSI throw >2500 m)
Firmware: Tom E’s open-source NarsilM v1.3 adapted by Texas_Ace
User interface:
[1] By default the GT98 is set to use the very intuitive Narsil smooth RAMPING UI. Instant access to a 28A TURBO mode is also provided.
[2] A more conventional discrete level MODE-SET UI is available as an alternative. Anyone of 12 pre-defined mode-sets can be selected.
[3] MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets.
Battery: eight button-top 21700 cells(include)
Driver: 12V, Texas Avenger V2
Reflector: aluminum, smooth finish
Lens: Glass with anti-reflective coating
Body: Aluminum with Type III hard-coat anodizing
Tripod socket: Standard 1/4 inch threaded (1/4-20 UNC)
Button: Tactile with back-lit rubber boot
Ingress rating: Equivalent to IP65, do not immerse in liquids
Weight: Approximately 3.8 kg
Dimensions: 135 mm Ø head x 337 mm length
GT98 uses free software distributed under the terms of the GNU Public License version 3
GT98 Anduril code from toykeeper/flashlight-firmware
Package Include:
1xLumintop GT98 flashlight
