I have friends living off-grid who’ve started looking for — specifically — amber/yellow LED lights for nighttime use
(some in the family, older with insomnia, have discovered the “no white light after 8pm” approach works really well for them).
I’ve given them SK68s modified by swapping in amber Cree emitters still with the stock driver
(these, I think: https://www.fasttech.com/products/0/10007033/1574707-cree-xp-e-1w-580-59… )
They work.
And I’m making them some motion detector “piss lights”
Now I need to make more and better lights — these will be for several families on the same farm and for hanging in regularly used spaces.
More help needed — more and better ideas.
Of course they hit the “next mode memory” curse with the SK68s
And they hit the “low battery suddenly no light at all” curse (reports from the outhouse at 3am were — irate — no moon that night, dark dark dark ….)
And they only use NiMH — limited solar power for recharging, and they know and don’t want to mess with Li-ion.
I’m trying out 4/3A NiMH cells (same size as 18650, mentioned in another topic) and drivers that will run off them, that I can put into 1x18650 hosts
So — I’m looking for more and better ideas.
Solar rechargeable yard lights with/moddable with amber?
Lots of 12v amber in auto supply, but not easy to use.
What else is out there? I can get the amber XP-Es cheap, and can also get amber PC Rebels ($$:money_mouth_face:
—> Can anyone recommend a cheap 2×18650 HOST light?
—> Can anyone recommend a cheap 2xAA HOST so I can use two ordinary Eneloops?
—> How about a cheap 3xAA host — do those exist? Or even cheap 3xAAA hosts.
Oh, and
—-> is there really a difference between a “2.5W” and a “1W” Cree XP-E emitter?
FastTech shows a variety of different SKUs:
Cree XP-E 580-590nm Yellow LED Emitter on 16mm Base
2.5W, Yellow Light, 16mm
SKU 2119706
Cree XP-E 1W 580-590nm Yellow Light LED Emitter on 16mm Aluminum Base
1W, Yellow Light, 16mm
SKU 1574707
