I am selling a brand new never used Jetbeam RRT-21. I decided on giving another light to my dad as a b-day gift so this one must go!
What else can I say, it is a GORGEOUS light. It is the XML model.
Asking $78—-$75(for BLF members) to Canada and USA, and will include a free Hi-Max 2600mah 18650 battery that has only one charge cycle on it.
Features
• Specially designed for Military, Law Enforcement, Self-defense, Hunting, Search& Rescue and Outdoorsman
• The Rapid Response Control Ring allows the user to select different levels of brightness smoothly
• Infinite brightness accessible
• Stainless steel retaining ring on the bezel protects the head from drops and impacts.
• CREE XM-L LED
• Max output of up to 460 lumens with an effective range of 155 meters
• New hybrid reflector specially designed for CREE LED, which allows for better beam quality, efficiency and throw capability
• Newly designed high efficiency broad voltage drive circuit
• Tailstand
• Impact-resistant accords with US MIL-STD-810F
• IPX-8 standard waterproof
Specifications
Model: RRT21
LED: CREE XM-L T6
Maximum output: 460 lumens
Reflector: Aluminum reflector
Lens: Toughened ultra-clear mineral glass with anti-reflective coating
Material: Aero grade aluminum alloy
Finish: Type III military grade hard-anodized
Battery: CR123*2, RCR123*2 and 18650 Li-ion*1
Switch: Forward clicky
Dimensions: Head diameter 34mm, Tube diameter 23mm, Total length 143mm
Weight: 137g
