FT XM-L2 (?)
Hi All
I just got my FT XM-L2, 5-mode P60 drop-in today… I was quite excited but when I went to try it out…. :frowning:
I’m a total newb at this and don’t have the background info to really be able to tell what is going on… all I know is that this drop-in is definitely not as bright as my SF XM-L 3-mode (much brighter)…
Upon visual comparison, they actually look the same… I thought the XM-L2 emitter was slightly larger?
The sticker on the drop-in say ‘XM-L B 2’… ( http://www.fasttech.com/products/0/10001085/1292200-ultrafire-xm-l2-lamp-cover-for-802b501bl2)
perhaps this is NOT an XM-L2 and the description is wrong?
What you have above is clearly an XM-L2 and the 2nd pic in that FT listing clearly shows an XM-L2 - you can tell by the LED mount - white around the LED as opposed to green for XML's. It's probably a T6 running at 2 amps, so not a burner, but depends on what you are comparing it to. Don't think there is much difference between a XM-L2 T6 and an XML U3, also, but diffeences in tint will make a difference as well, and the FT listing tells us nothing much about the XM-L2.
XM-L2's are the same exact size as an XML, but the white and green background is one simple way to tell the difference.
ah… ok thanks for that tip…
i guess this would be a driver ‘issue’?… if I wanted more kick I would have to mod the driver?
(i tried to do a tail cap reading but the probes on my MM are too big to slide into the tail cap…. )
XM-L has lines across the die for current spreading,
XM-L2 does not.
XM-L and XM-L2 are exactly the same size. 5x5mm.
XM-L2 is brighter at a given current and little brighter for a given power.
Well, you really need to know what you are comparing, or clue us in. Do you know specifics on the SF XML drop-in, like amps, bin, tint? I would suggest you request details from FT as well - what exact bin and tint is in theirs - they usually respond quick and with details. XM-L2 will beat out an XML for equal amps and equal bin/tints, as Ramblings is stating, but "equal" is a big assumption here...
ok will do…
thanks!
Switch light on and remove tailcap. Set DMM to 20v setting. Put positive probe on battery negative while it is still in light. Use negative to ground to light body at tail. Depending on driver you may need/want to get readings for different modes by quickly un-grounding and re-grounding negative probe. Best to do so in order to confirm initial mode is the one you thought it was on.
ah… ok I did try that, but I thought the reading represented something different than going through the tail cap? (I found the guide on cpf that goes through the different readings… will confirm…)
thanks!
A tail cap reading is generally amps. You normally need to move your red probe in the meter to the 10A plug and black probe stays put. Set dial to DCA setting. Then proceed as gottazoom said. Check your meter manual to be sure.
Hi Guys,
Question for you, (this has been bugging me a bit on my BS Terminator,) is there a way to tell apart the XMLU3 from XMLU2?
The tint/color/temperature of the Terminator is much cooler/whiter than the other U3 lights I have or had. (Crelant 7G3CS, Crelant V21A)
Thank you in advance for your time and help.
This.
Easy way to tell if you have an XML2 is to look closely at the yellow part of the emitter visible through the dome. If you see a bunch of parallel lines in it (current spreaders) then you have XML. If it looks completely uniform with no visible lines then it’s XML2.
If you shine the image of the XML2 die on an wall with an aspheric lens you’ll see a diagonal grid of dots in the image of the die. These dots are much smaller than the current spreaders in the XML1.
yes… sorry… in my last post i got confused with my E09, LD01, and Saber 1A… I did do a tailcap reading with my L2P… still trying to get things straight…
I’ll re-measure with both drop-ins and see what I get… in the meantime I have a new driver incoming (my first ‘real mod’!!)
thanks again for the clarification!
