Anyone seen a GITD oring for the FW1A or know what size oring is between the lens and bezel?
23mm OD is for sure. Diameter of 1mm will need confirmed by someone else.
I’m curious if the khatod PL114506 optic will fit. I’m not a fan of reflectors and I already have an FW3A.
[/quote]
I can measure that tonight when I arrive home ![]()
I have some GITD o-rings, I can try them later and give you an answer later ![]()
Sorry for the late reply!
Here are some photos and measurements.
I couldn’t get the GITD o-ring but here you can see the diameter of the stock one! Hope it helps ![]()
This is perfect, thanks!
THANKS!! ![]()
https://www.aliexpress.com/item/1289152853.html
https://www.aliexpress.com/store/group/22-5mm-LED-Lens/219000_251014010.html
Looks like the diameter is just about perfect! They might just work without the lens with a FW3A bezel.
