Put me down for one please.
I interested for 1 piece with Nichia 219c NW
Emitters are not defined yet!
Add me for one please!
Ok, i need just 1 piece.
This is true.
BTW, what did people think about the muggle-mode UI poll? I was thinking of doing a similar one for emitter type, if people found the poll method acceptable. Itâll need more explanation though, since the emitter tradeoffs are more complex.
I thought that poll was superb. Easy to use while also allowing for degrees of opinion.
Are we talking 3000 lumens out of this lamp? Sorry if I missed the output(s), but whatâs the turbo Lumens and time as well as a sustainable âhighâ lumems spec if there is one at this point? If not, a target brightness would be interesting.
Please and thanks!
The FW3A specs are vague because the emitter type hasnât even been nailed down yet. However, itâll probably do somewhere around 2000 to 4000 lumens on turbo. And the highest sustainable level at room temperature while tail-standing will probably be under 500 lumens, due to thermal concerns. The sustainable level during actual use depends on how the light is cooled⌠itâll be capable of more in cold weather than in hot weather.
Perfect
Thank you
Understood and clear
Could i please be added for a 2nd, i really like the direction this light is going
I didnât vote on that poll, I just expressed my preference here (if I recall correctly)! Is it still active?
Concerning the emitters, as the option is still open, I would consider to make a poll!
BUT, before opening it, I guess the ârealâ options must be considered before making a list. Due to the availability of the LEDs, due to the original concept, due to the interaction with the driver and heatsinking, and so onâŚ
A general thing as âXP-G3â / âXP-G2â / âLuxeonâ / âXP-L HIâ⌠will probably not be enough for this âtough crowdâ (me included).
If you, TK, or the FW3A Team advance with this, I guess the âreal optionsâ (type of LED, bin, etcâŚ) must be discussed first so that we donât âdemandâ or âdaydreamâ about something that will not be possible!
My opinion of course
As an example, there is a group buy on the Wuben TO46R and TO10R that is facing some issues due to a sudden lack of the expected High-CRI LEDs. Member =the= is trying to reach a final product along with the manufacturer.
So, looking to this, the stocks or the possibility to get the emitters must be considered before even givin us âoptionsâ!
Thanks for the initiative and the constant information you´ve been giving us TK!!! :+1:
Please make sure that the head is NOT glued. Iâm fine with having no host option available, but would like the option to upgrade the LEDs myself in the future.
Also⌠is the clip removable? For those of us who donât use clips, itâs just extra weight in the pocket.
Not all of the first prototype where glued. One off the Germans disassembled the tail. The clip is hold in place by an o-ring (not in the cut away)
You clamp the outer tube to the inner tube and you clamp the clip (over a spring = o-ring) with the back piece. And on the other end you need contact to the head.
Donât know how easy it is to assemble till everything has contact. Maybe glue is away to go.
Can I go on the list for one?
I realize the inner tube is relatively thin but still wondering if a copper inner tube would be worth considering?
Cu supposedly gets +40% additional thermal conductivity and mass compared to Al; and anodizing on inside of main Al body should be enough to insulate electrical signal.
I realize the inner tube is relatively thin but still wondering if a copper inner tube would be worth considering? Cu supposedly gets +40% additional thermal conductivity and mass compared to Al; and anodizing on inside of main Al body should be enough to insulate electrical signal.
I don't think this will be carrying any "real" current, just a little signal to control the light with. The extra cost of copper might not be worth it.
A lesson I learned from Liteflux lights is that when you add all of these extra mechanical connections to the signal path you'll occasionally need to clean or tighten all of the pieces. Not a deal-breaker, just the way it is.
In mission-critical use I'd prefer a big knife switch with gold plated contacts, for EDC this should be fine. Time will tell.
_(this is where I'd put a little smile eating popcorn but there are none in my selection box)_
I would think a Cu inner tube would have near zero benefit. I also think any ideas that get thrown up are kind of a moot point since it was never up for discussion, this is Fritzâs design.
Actually a copper inner tube would be counter-productive.
Those LEDs are going to generate a lot of heat. The inner tube sits against the battery. Last thing you want to do is provide an easy heat path to transfer that heat to the battery.
Myself included really like the way this light is shaping up. Love reading all the different ideas and opinions. Being fairly new to decent torches I am learning quite a bit. I donât know what my original number is but I would really like to be put down for another light, for a total of 2 lights. I am aware that this light is still in itâs infancy but I donât want to be left in the dark (see what I did there) when this thing rolls out. Thanks to everyone involved.
Like TK said a little while back:
I think if it sells well, they might make it from titanium, brass, or copper in the future. Iâm looking forward to those.
