Iām glad to hear about the SST-20, both because it should avoid further delays with a high-CRI option, and because I think itās a better beam shape for most use cases than the LH351D in a triple (though Iām quite fond of the latter in a reflector).
SST-20 is perfectly fine with me. Iām glad theyāre moving forward. Iāve got some 4000K LH351Dās on hand to try if I donāt like the SST-20.
Relevant info for those who like to mod:
AED still has 5000K LH351D, 90 CRI emitters available. Djozz and Bob McBob have both verified that when dedomed, the Samsungs get warmer , throwier, and the Duv decreases (goes from slightly green to neutral or even slightly rosy).
Output does decrease, but the LH351D should still have an advantage, especially at high currents. If Djozzās measured 19% lumen loss is typical, then adjusting the figures in the datasheets for common bins yields (emitter lumens, not OTF):
CCT
700mA
3000mA
LH351D S2 5000K sliced
~4300K
215 lumens
692 lumens
SST-20 J4 4000K
4000K
193 lumens
556 lumens
The SST-20 should still have a bit better CRI and R9, and perhaps also slightly better throw.
Yesterday I installed SST20 4000K 95 CRI in my modded Sipik 58 zoomie with LED Lenser style optic and electronic switch, and also in my Jetbeam TCR-01 triple.
This emitter is growing on me. I quite like it actually.
Honestly all I care about is having a cheaper option than X-PL HI, since that will offset the cost of buying something to replace the emitters with if I donāt like them. Have no real interest in the X-PL HI so not looking forward to paying anything additional for them (unless they decide to offer a 4000 or 4500K binā¦ ).
This 219C is nice but 219B SW45 and SW40 are clear winners for me, but I donāt like the idea to have my eyes and brain āshapedā by and āshapedā to the 219B. Before the E21A series, this 219C was (and still is) a good option. R9050 type shows its limit compared to R9080 though.
Clemence has indicated he has plans to maken a E21A triple board:
I donāt think the E21A is well suited for a FET driver, but it could be an option to remove the FET from the driver, and youād still have a nice 2.8A, floody, pocketable light with excellent tint and Anduril UI. The ramp would top out after about 2.2 seconds instead of 2.5 seconds.
Ah, sounds good. Iāve a Q8 with the sst20ās I quite like, and to me and to most people Iāve talked to, they are a bit yellow at lower currents, and very nice at higher. Not green in the opinion of most people, (though TK says lemongrass). For 4000k being above the BBL means being yellow. Iām pretty okay with them, although I might like the extra output of the lh351d, so Iāll probably just get these instead of waiting and let the D4 be the one to be super high output. They should be comparable throw, while being high cri - a perfect option for those who were on the fence, and who wonāt mind the tint. Iād still like 219b in one though.
Iām glad the optics are on the way. It seems we are one step closer. Will there be final prototypes sent out for review before production? Beating the dead horse, I will say again, it could save a lot of problems in the long run.
