No, just take the one piece optic out, make sure the O-ring in the bezel is seated properly, put the Carclo on the MCPCB, put the lens in the bezel, and put if together.
Ok, thanks. I didnāt really check the o ring and it seems like there is just a little gap that wasnāt there before. Iāll take another look at it.
Sure thing, my pleasure. Did you use a lens Neal sent you or an aftermarket one that was a bit thicker? If a thicker lens was used that could result in a minute gap.
Mine doesnāt spin, but it isnāt stationary. It wiggles a little up and down and will move just a LITTLE clockwise and counter clockwise. Is that how it is supposed to be? Does that affect the thermal grease any?
Does the 10507 create artifacts in the beam edges (not a smooth ROUND circle) when you rotate the light? The one piece optic my light came with (sst20) put out a floody smooth circular beam. I liked it but it did take away a little throw. I put the carclo 10511 from my nichea light in it. Not as floody now but there are artifacts in the beam when you spin it. Wasnāt sure if the 10507 would make it worse.
I know - donāt spin it and problem solved. I know itās there now though. Also for close in work, itās just more obvious.
If you shine it on a flat surface you do see āartifactsā .
The closer the flat surface, the more obvious the artifacts.
They are also a bit more abvious with the 10507 than the 10511.
But in everyday use I hardly notice them at all. I guess it just boils down to personal preference as to what is acceptable.
