FW3A T85 to T1616 Upgrade
I’ve done several FW3A driver upgrades and decided to make a post with instructions for anyone that wants to upgrade their FW3A driver with a T1616 MCU.
T1616 benefits:
  1. Lower lows due to dynamic PWM
  2. RGB(3 channel) Aux
  3. Full Anduril2
  4. T1616 doesn’t require thermal calibration because it’s calibrated at the factory.
Link to @Adair21 FW3A T85 to T1616 Adapter PCB:
https://oshpark.com/shared_projects/kG1HW0OV
Link to T1616 MCU @ Digikey:
https://www.digikey.com/en/products/detail/microchip-technology/ATTINY1616-MNR/7354618
The T1616 MCU requires different firmware.
Link to @Adair21 Github:
Stock Driver:
Bridge all 4 pins with solder, so we can lift the whole side all at once.
Heat one side and lift, then do the same to the other side to remove T85:
Remove unneeded Capacitor and Resistor:
Use Solder Braid to clean up Solder:
Clean with Isopropyl Alcohol:
Mock fit adapter PCB, and trim to fit:
Add flux(maybe a little less than I did):
Apply a small amount of Solder to the tip of your iron:
Apply Solder to 1 connection and verify the adapter PCB is still lined up correctly:
Apply Solder to the remaining connections:
Clean everything with Isopropyl Alcohol:
15 Thanks
Also if anyone is interested in doing this mod to a FWAA you can find my FWAA T85 to T1616 Adapter PCB here:
https://oshpark.com/shared_projects/yj1Lj3DV
**Note:**Your FWAA driver version must be v1.1! Driver v2.2 has a QFN T85 and it’s not compatible with this adapter.
This is great, thank you for the step-by-step.
As soon as my adapters arrive from OSHPark, I’ll be trying this!
Which is sadly discontinued, I’ve been trying to find one (to fix my FWAA) to no avail.
I’ve had two of the v2.2 drivers die while I was trying to flash them, the MCU got bricked in the first one (random hardware singature), it got wiped and wouldn’t accept a flash in the second one.
If someone has one and can reverse-engineer it, I might be able to put a few together.
I have a spare v2.2 if you’re interested PM me.
The problem is they keep dying when I try to flash them, so it wouldn’t be of much use to me :frowning:
I plan to flash mine.
I’ll let you know how I make out.
Great write-up and pics, thanks!
Would this work with an FW1A as well?
Great Question!
Yes, the FW1A uses the same FET+7+1 driver!
Awesome! An added benefit with Anduril 2 is the firmware protection against the switch/signal getting stuck and ramping all the way up, which can happen with these light (gave me a scare when it happened to me once).
I wonder if this would work on Emisar /Noctigon lights as well
Dont forget to check and if needed re-calibrate thermal protection. Because now T1616 is even more isolated from host. At ideal situation for an accurate measuring T1616 should be soldered straight on host. Now you are measuring temperature of that PCB
I’d like to do it…but once done, where can I find the new firmware?
Hank uses T1634 on most of his lights so this won’t work.
Would you know where to get these i dont even know what they are called
That won’t work on the T1616.
You need a 3pin pogo.
Gchart sells them in the Buy/Sell section
Ended up reverse-engineering it, and made my own T85 and T1616 drivers (with the help of some community members, as it was my first ECAD project).
Sent them off to JLCPCB to have them made, hopefully they work.
6 Thanks
Depending on the wiring, it’s possible it might work with the TS10 firmware, as both are 7135+FET.
Otherwise it might just need slight modifications (swapping pins around in the HWDEF)
Well, that was fast!
The combination of novelty, boredom, and free time can mean a surprisingly fast turnaround rate for new projects.
