Mine has the edge at 3 o’clock with all 3 pads soldered. The pad at 4 o’clock has a lot more solder than the other 2, especially the one at 8 o’clock, so the bottom of the spring over the trace is raised up and won’t make contact with it even when I push down hard on the spring.
This is a good thing I guess
DBSAR
(DBSAR)
662
Sound like yours is good and solid with a bit of a gap over the trace with no risk of spring movement. :+1:
contactcr
(contactcr)
663
While you can never be too safe with the spring it doesn’t seem like we are convinced this is the only variable that caused this.
Did you ever take a good picture of the driver side? Does the signal pad line up nicely where your driver is seated? Kawi had one that didn’t so rest assured i’m not just trying to agitate you DBSAR.
Lexel
(Lexel)
664
Aux boards for the FW3A are now on sale
Prototype with ice blue, pink and warm white
DBSAR
(DBSAR)
665
i didn’t take a photo or took the head apart yet, but its looks slightly off center, but no burn marks.
pennzy
(pennzy)
666
Mine is only soldered in one place. I guess I will solder the other two , maybe rotate it also if no gap.
Yep the driver is quite smaller than the driver seat/pocket…some measurements…
seat ID
driver diameter
driver flat diameter
batt tube ID
driver smd/clearance pocket ID
The 2 GB and the 1 X-L HI 1A lights, the drivers are a press fit, zero slop…… this is one of two of the Nichia Lights….
JasonWW
(JasonWW)
668
This does not seem likely. If the spring touches the trace, it’s like pushing the button. It ramps up, but then the thermal stepdown should activate.
What your describing, the thermal stepdown not activating, sounds like a driver short where the driver is bypassed and no longer in control of the LED’s.
Did you check out your driver/head area to see if anything looks shorted?
JasonWW
(JasonWW)
669
I think I’ll try shorting the spring to the trace to try and duplicate the sceneries described. I’ll scrape away a bit of the solder mask and solder a single tiny strand of a copper wire from the trace to the spring. I’ll see if it burns through like a fuse or what exactly. It might be next week before I can do it.
teacher
(teacher)
670
JasonWW
(JasonWW)
671
Not at all. Like I said earlier, in your case it sounds like the driver got bypassed somehow. From what I can see as to how the switch pcb is designed, shorting the spring to the trace should only simulate the button being held down. The thermal stepdown should activate. I assume it will, unless a held down button somehow bypasses the stepdown software. Toykeeper probably knows what the code will do.
High current usually goes through the vias on the pcb. Maybe the trace is weaker in comparison to the vias and that’s why it got overheated. I really don’t know. It’s a mystery.
I figure using a tiny wire strand will act as a fuse so I don’t risk burning the trace. I can fix the trace if it should burn, but that’s extra work. :confounded:
Rdubya18
(Rdubya18)
672
I can’t lose this nagging feeling that this is an effect of a loose driver retaining ring . I am in no way as knowledgeable as most of you , but the lights behavior when the ring is loose is exactly how DBSAR’s did . Is it possible with the current running wild , and a shock ( blow ) to the tail at that moment , caused the trace to short ?
contactcr
(contactcr)
673
No idea why he is so defensive about this but i’m with you i’d rather know that we found the real cause and not a side effect of the primary issue. Sending people down some rabbit hole of spring soldering only to find out the signal tube bridged something on a loose driver (hypothetically) is counter productive. If a revision is to be made to assembly or otherwise the real cause needs to be determined.
pennzy
(pennzy)
674
No harm in getting to the bottom of this. I’d like to know if I need to lock mine out or exactly what mod is needed or if this is just a fluke.
contactcr
(contactcr)
675
That’s the thing with e-switch though. Firmware lockout does nothing if it shorts. Physical lockout is hard to do on this light and not recommended anyways cause nothing is glued. Until we know more I would suggest just making sure the driver is lined up and centered and the retaining ring is not loose.
JasonWW
(JasonWW)
676
DBSAR, did you change your light to ramp to Turbo or does it only ramp up to 1000 or so lumen like stock?
I was testing to see if the thermal protection would still kick in when you hold the button permanently, but I forgot Anduril doesn’t ramp to Turbo (at least not in stock form).
JasonWW
(JasonWW)
677
Okay, I found time to test this today. Nothing bad happened. It just ramps up to the stock level. No Turbo and no high current going through the tail circuit. There’s no need to worry about the spring shorting the trace.
I took some pics and a video to show what happens. I’ll put it in the next post.
My point is something else happened with DBSAR’s light that caused it to go to Turbo and burn that trace. This is still a mystery. I suspect something in the driver came loose due to the fall and the driver got shorted somewhere in the head. I don’t really know, I’m just trying to eliminate things to narrow in on the true cause.
Interested to find out the root cause, if not just the tail trace. Still, it sounds like it’s worth soldering the spring properly, to prevent it from damaging the tail trace.
Nev
(Nev)
679
It may be just a bad design & did what it did because this torch can produce loads of lumens but it’s not really built to handle it , mine started smoking & melted the feeble wires , I think lemontop ought to watch out , because selling this little time bomb to muggles is gonna end up in disasters & people getting hurt.
JasonWW
(JasonWW)
680
Here are the pics.
Copper strand added.
Here is the video. Sorry about the length.
Note, at 6:10 it seems the inner tube temporary lost contact and reconnected. This simulated the switch being released and pressed again quickly. You can see it ramp down.
Something else I just noticed. Most of you probably already knew this, but I didn’t. The metal dome has 2 tabs that keep it located. I thought the tape held it in position which seemed fragile. In reality, the tabs lock it into place and the tape is only there to aid assembly. Neat.
