I think she sent it to Lumintop shortly after that. Some people have flashed their own lights, but I don’t think this newer firmware has showed up on factory lights, yet. Maybe it has shown up on a few, I seem to recall people saying they have 2 different lockout mode brightness levels. That’s a sign of the new firmware, right? I’m not positive on this.
on my newest light from Vipon deal I have a Flash midway before the ceiling flash — I was wondering what that was—I guess I inadvertently set a memory point — I’ll try and reset it to verify
I tried to move that flash midway - no dice - I guess that flash means something else
The flash indicates when you switch between 7135x1 regulated mode and 7135x8 mode. This is a set point and can’t be changed. As far as I know, all FW3x lights should do this.
You missed the part where he said his other FW3A lights did not have this extra flash. This must be a new thing. (it might be the ceiling was set a bit higher causing 3 blinks)
I’ll check the output of the middle blink tomorrow when I’m home —- The first blink we all know is the Floor setting and the last blink is the Ceiling that we program in the lights —- this is the first I’ve heard about 1/7135 or 8/7135
I find it odd Toykeeper hasn’t chimed in on any of these issues we have been talking about —————- :question:
I was almost certain that there’s a blink at the ceiling setting —- mine blinks at around 700 lumens right where my ceiling is set —- there is also a slight blink when you hold at turn on that starts you in your floor setting —- this light is too smart for me
It will blink (or blip, as it is called in the source) at several points:
If you hold from off, after the hold timeout to notify that it is safe to release the button without blinding yourself (before the blip the press would be interpreted as a short press)
At the transition from single 7135 to all eight 7135
At the transition from all 7135 to FET. In the default config of the FW3A this is also the ceiling.
At the ceiling
There are some other config related cases, but we are talking just about blips during ramping.
Also note that the first one doesn’t happen in the latest development firmware anymore because the button timing was changed (so that the light turns on when it is clear whether it was a long or a short press).
Hey, your right, I was wrong. I set my ceiling to 5 clicks. Now I ramp up from moon and I get 3 blinks. One at the 1 x 7135 to 8 x 7135 change, one at the 8 x 7135 to FET change and one at the new ceiling level.
Maybe Chops light has the ramp ceiling set higher than normal and that’s where his extra blink is coming from.
I see now that this is correct ——I’m thinking my mid blink is lower because I went to Samsung LEDs —therefore its reaching 8-7135 at a lot less lumens than the XPL version I have —- I also am thinking the crazy ramping down and slowly ramping back up is because with the Samsungs 700+ lumens is out of regulation — I don’t know if this is correct —-
