That sounds quite unacceptable to me and a bit dangerous. My old man response would be to either retire that light (remove battery) or else return it to the original 18650 tube. I guess I no longer have the patience to do a bunch of investigating and repairing to make it reliable.
Barring a software bug or unlikely corruption of the ROM, software lockout should guard against this. Given the flaky nature of the FW3As switching I use it whenever itās not in my hand. Thankfully Iāve only had issues with it activating while clipped to a pocket whenever Iāve neglected to lockout - presumably because that switch is all too easy to bump.
It is an early one. In particular, this is the one with the ToyKeeper icon on the switch. My full size 18650 had this same trouble very early on and was resolved after cleaning and reseating the tube. Hasnāt happened again since.
Thanks. I did clean everything before, which shouldāve taken care of the problem⦠not sure how to ācheck alignmentsā as I canāt see inside the tube when closing up. But I did not know about that tailcap retaining ring tip. This one does have a retaining ring, unlike my other FW3A. One of these days I will see about flashing firmware, but right now Iām not set up to do it. Good to know that Anduril 2 has a failsafe to mitigate that problem!
Hi everyone! Iām new here, but reading quite a while.
Just got my fw3a sst-20 4000k from aliexpress and wonder how to check did I have a āfull versionā with all the power channels or missing some.
Head inside looks just like on the left (I mean photo in the first post). What else can I check?
Mainly just count all the 7135 chips. Thereās 6 on the back and 2 on the front, but the front side might require unsoldering the 2 main wires to look at it. You can check that the brightness when ramping up or down is smooth.
There should be a short dip in power as you ramp between the 7135 chips and the FET. The newer firmware might be different though. Letās see what other folks say. (My light is a very early one)
All 6 are in the back, but donāt want to unsolder anything to count those on the front.
Ramp is all smooth and there are two āblinksā, one on the high and one in somewhere in between.
I checked mine. When ramping up there are two short blinks. One when it switches from channel 1 to 2 and another from 2 to 3.
Iām still not sure thatās a guarantee you have 3 channels in yours. Iām not even sure which software version your light has. Hopefully someone can give you a more concrete answer.
If the ramp is smooth I wouldnāt even worry about it.
They can actually handle higher heat than that, but briefly and people have ran the leds to the point of the heat melting the solder. My point was that 85° is a good upper level to not exceed due to the battery. Then there is a huge gap from 85°C to 200°C. So no one really needs to worry about the led or driver components. Worry about battery heat first (and not burning your hand). Donāt waste time worrying about the driver and led. They are quite robust.
JasonWW, SammysHP, thank you for detailed explanation!
[quote=JasonWW]
[quote=Alexxey]
Actually I checked one more time, ramp is not so smooth near to moonlight level. I can see several barely visible steps (starting from moon) before it gets nice and smooth. Is it same for original version or is it a bad sign?
Itās not very likely you got an old original model with all 3 channels. Itās not the newest version for sure either which is one channel (no 7135 chips). So you might have that middle version. Itās hard to say for sure. Even my early model is not perfectly smooth around the very lowest levels.
You should decide if whatever version you have is going to work for your needs and not worry so much how many channels you have. That is a tiny detail that makes a tiny difference. Even a FET only version should be pretty decent except for the very lowest levels around moonlight. Itās really not that big a deal as long as itās operation and functionality is good.
Yeah I know, itās just some deep desire of a perfect toy
For sure itās not the old original version, but what if Lumintop decided to make fw3a great again? I guess there is no way to tell other than unsolder something.
Comments like this made me worried in the first place actually - Which Lumintop FW3A to buy? - #10 by BlueSwordM
