FWAA a Jekyll / Hyde Review
As friend to BLF Hank, of International Outdoor, (https://intl-outdoor.com) has gone a different direction than tiny LED flashlights; by creating his incredible high quality versions of LED flashlights - I (unfortunately) had to search elsewhere for a small single AA LED flashlight with ramping.
On Black Friday, while on Amazon, I used my credit card reward balance to try two LiminTop FWAA flashlights. Why try two you wonder? Because they were from LuminTop and I knew I had a 50/50 chance of even getting a working light.
Instead of dumping on LuminTop, I’m going to juxtapose the good and bad of these tiny 1 X AA LED flashlights.
Good = Jekyll (J)
Bad = Hyde (H)
The U.I., Andúril, same as Hank lights. So this is a moot point.
Seller
J) Amazon, easy to return a defective item.
H) The Amazon Store was LuminTop.
Fit-n-Finish
J) The anodizing of all parts match pretty well.
H) The threads are as enjoyable to use as getting beach sand out of your crotch.
Build Quality
J) No missing parts.
H) Not completely assembled. The circuit board retaining rings in the front were loose and had to be tightened to be able to completely screw on the heads.
Soldering
J) Circuit board joints seem good and clean.
H) Emitter board joints are horrifically terrible and filthy.
Optics
J) TIR optics with anti-reflective glass lens.
H) Too floody for practical use. I had to polish the optic on one light. This tightened up the hot spot and made the beam more useable. I could only do this on one flashlight because the bezel on the other had apparently been partially screwed on then pounded on the rest of the way; making it impossible to get off.
Care
J) The clip seems tough for its size.
H) After a few days of casual use, the anodizing already has snail trails.
Feeding
J) Eats 14500 and 14505 batteries; though with much diminished output - as expected. It accommodates different length cells!
H) With three emitters, battery life will be short.
Summary
J) If Hank would make his version of this flashlight, I would purchase several.
H) If I had not essentially gotten two free and easily returnable flashlights, I never would have tried them. The literally pounded together light will be returned.
