It really is a tiny light about the same size as an X6 but different too. I can't explain it but you see the difference.
Looks like you have your work cut out for you. Kronos and I need our reviews on our desks by morning :bigsmile: (Just kidding....tomorrow afternoon is ok. LOL)
Is this light safe to run with non imr battery chemistry? I currently only have Panasonic ncr18650b, Sanyo UR18650A, Sony US18650GR, LG LGDAS31865. If I need to get imr batteries to run with this what are you recommendations.
There is a simple solution to this. If we can get 250 buyers, then include an extra copper board with each light. Charge an extra dollar or two if needed.
It varies. From memory most NCRA’s and NCRB’s are only good for 6A continious draw.
If I were you I’d be considering Panasonic BD’s . They are high capacity and high discharge (10 amp continuous) but despite the link they are actually unprotected cells, so you must be careful not to discharge under 2.5V.
If you don’t want the hassle of worrying about the voltage of your cells stick with protected ones.
It’s usually only modded lights that pull high amps from a single cell when you need IMR, but alot of people prefer IMR to ensure they are getting the maximum performance out of their light (due to the higher internal resistance associated with protected cells)
Oh geez, it’s the X6 bullcrap all over again. Change the emitter and it pulls half the amps, makes perfect sense.
If this doesn’t pull 4 amps like the stock one, I’ll just cancel my order and get an older (and brighter lol…) XML U2 version.
Let’s not go panic stations just yet though, full faith in Krono!!!
NOBODY knew about the spec change in XM-L2 when the X6 GB was occurring. We are wiser now. I do not know about the discrepancies that Kronos is referring to for the D80-SE but I DO know that he will look for a solution - and find it.
We as a group have shown the manufacturers that of they listen and adapt then they will benefit. That is not lost on our vendors either. I believe that Karen will get LS to listen...but it may take a bit of time and persuasion :)
