[GB ended,discussion only] CRI > 80+ NICHIA 2000K-6500K [E21A/219B/219C/319A/144A/757GT-F1(Optisolis)]
Clemence, I am considering modding a coast hx5. This light has a tiny board mounted on a tower. I wonder if I could cut just the very center of your single board and then scratch the white insulation in the right place to expose copper for electrical contact?
Counting pixels I redid your calculations and arrived at 1000 lm@3.02A with Vf of 2.91V. 114 lm/W. A far cry from my previous calculationsā€¦do you have any idea why is it so?
EDIT: I made a mistake. Itā€™s over 3.2 A with slightly higher Vf. Still over 100 lm/W, but even farther from 170ā€¦
[quote=Agro]
[quote=clemence]
Use it as rough estimation only.
The real output must be much higher though. I used wall bounce method only to check the maximum current capability. Letā€™s wait Djozz test result if he has the time
- Clemence
OK :beer:
In my Armytek Wizard Pro testing, at low current (firefly modes) even the R9080 is more efficient than XHP50 CRI70. Then as the current went up, the efficiency got lower.
- Clemence
I did my first mod with the E21A sm603 R9080, and it makes me like cool white tints much much more :slight_smile:
The Optisolisā€¦
- Clemence
Very curious about these
Have you tried mixing them with 5k?
No, I just have the 6500K ones.
And mixing leds is a bit of a believing thing, not real. For me it would only be useful to obtain a colour temperature that is not available, so out of shortage of supply. If you mix two colour temperatures, the spectra simply add up and you have no different tint than if you use just one led of the in-between colour temperature, but not as good because the light will not be perfectly mixed.
Correct! Mixing several different CCTs will also (in most cases) results in lower CRI than individual CCT. You can check Maukkaā€™s test to see it. Itā€™s more like a trick.
- Clemence
Of course you are right. My goal is to get the high noon tint of 5700K by mixing the 5K and 6.5K. Re the imperfect blend: I want just a mule and I am sure that for this specific quad board with the LEDs positioned so closely to each other, the two tints would blend perfectly when the light is more than a few centimeters away from a target.
That sounds a good reason and a good way to mix the leds :slight_smile:
Sorry guys, Iā€™ll try to stock more CCT later. The VR16SP4 was designed for CCT switching (Warm/Cool option in a room), not mixing in the first place, to compete in general lighting applications. But later found that itā€™s a perfect little board for tint/CCT mixing too. The ideal solution is of course to use fixed CCT.
- Clemence
UPDATE 180217:
Very limited samples available for purchase at minimum cost only (freight & duty tax)
https://www.virence.com/blank-rwrlr/copy-of-nf2w757gt-f1
https://www.virence.com/blank-rwrlr/nf2w757gt-f1
- Clemence
That is what Iā€™d love to have in an aleph type LE. But programmable drivers are unavailable. Just got those multi-color driver that djozz modded the other day, will see how this quad setup works with this driver.
Do you think you could install them onto a quad board? Iā€™d like to have one with 4x of 5K
Sorry, I only have the 3000K and 5000K samples. No, it doesnā€™t fit the VR16SP4 MCPCB, only on the VR16S1 (offset). Being a low power LED, you can use almost any decent two pads non DTP boards
- Clemence
I see, I just wanted to put four 5K LEDs on one board to get 200+ lm from a single LE. I am just wondering now if there are any triple or quad 2-pad boardsā€¦
Sorry if thatā€™s already said, but from the optisolis pictures, you can even see two separate dies
