[GB ended,discussion only] CRI > 80+ NICHIA 2000K-6500K [E21A/219B/219C/319A/144A/757GT-F1(Optisolis)]
Sorry guys, I’ll try to stock more CCT later. The VR16SP4 was designed for CCT switching (Warm/Cool option in a room), not mixing in the first place, to compete in general lighting applications. But later found that it’s a perfect little board for tint/CCT mixing too. The ideal solution is of course to use fixed CCT.
- Clemence
UPDATE 180217:
Very limited samples available for purchase at minimum cost only (freight & duty tax)
https://www.virence.com/blank-rwrlr/copy-of-nf2w757gt-f1
https://www.virence.com/blank-rwrlr/nf2w757gt-f1
- Clemence
That is what I’d love to have in an aleph type LE. But programmable drivers are unavailable. Just got those multi-color driver that djozz modded the other day, will see how this quad setup works with this driver.
Do you think you could install them onto a quad board? I’d like to have one with 4x of 5K
Sorry, I only have the 3000K and 5000K samples. No, it doesn’t fit the VR16SP4 MCPCB, only on the VR16S1 (offset). Being a low power LED, you can use almost any decent two pads non DTP boards
- Clemence
I see, I just wanted to put four 5K LEDs on one board to get 200+ lm from a single LE. I am just wondering now if there are any triple or quad 2-pad boards…
Sorry if that’s already said, but from the optisolis pictures, you can even see two separate dies
Yes, far from the ideal flashlight type of light source, but maybe good for a, not so bright, flood light.
Optisolis = asymmetric
Asymmetric pads, asymmetric dies placement, and asymmetric blue pumps too
- Clemence
There’s one possibly positive thing about mixing CCTs though. If you happen to get two mildly greenish emitters with large enough CCT gap, you can mix them and land closer to the BBL since the average is completely linear.
Ra/R9 of 95/85 minimum is pretty exciting, though that emitter doesn’t look good for flashlights. A panel with 200 of them would be fun, much like the Viltrox camera lights.
I wonder how does a board in those cheap cob lights look like? Whether it would accomodate a string of these nichias?
Actually, that’s not what they’re referring to.
The actual spectrum of any “white” LED is a strong peak in the blue, a dead zone around teal/bluegreen, and then a slow rise towards the yellow/orange, then falloff in the red.
If you were to combine the 2 individual spectra of, say, 4000K and 6000K, it wouldn’t exactly equal the spectrum of a 5000K LED. Being that cooler lights are generally a little more efficient, you’d be able to guesstimate its combined CCT to maybe 5100K instead, but the balance of all the individual colors wouldn’t be identical, even if you were to have a 5100K LED.
It’ll likely be close, but not exact. And the result can be a lower CRI if they’re not “in balance”.
what is the difference with the 6500k 9080 and these?
thanks.
The Optisolis is currently still under preparation to hit the market. It’s light quality is simply Nichia’s best to date. Far better than E21A 9080.
I made a spectrum comparison pictures in the product page, please check it.
But….It’s a very low power LED rated for only 0,3 watt per LED.
- Clemence
thanks so not really much for a flashlight?.
even Yuji LED don’t venture this side for flashlight LED’s which is a shame.
thanks,
For flashlights uses, even the “modest” R9050 light quality is already extremely good compared to “common” CRI. As long as you are not lighting up next to someone else with Yuji or Optisolis of course.
Here’s the comparison chart:
- Clemence
I wonder if there are any 16/17mm triple mcpcbs with 2-pad contacts, suitable for the optisolis? I think that standard xp boards could be used if the central pad is insulated by kapton tape but the LED would sit on a very narrow margin of the pad. I’d rather avoid this hack
Someone has messed up those graphs above: in the 5000K graph it seems to me that R9050 and R9080 is reversed, in the second graph the red line is missing.
Uhm….that’s me. Thanks for pointing that Jos.
3000K chart fixed.
And those 5000K chart wasn’t misplaced. I used the chart from Nichia data sheet:
- Clemence
