Hype is one thing, but out-right lying is fraud. For this <$8 light: http://www.gearbest.com/led-flashlights/pp_44313.html, it's listed as having a SS bezel. So I opened a ticket about the error and my disappointment. GearBest's answer: how bout $2 off? I don't really care about the money, I just wanted them to fix the listed spec - they simply would not answer me on that question - totally ignored the issue.
I, as most have, got used to the mis-information about lumens, and can understand the confusion between copper and brass, but aluminum vs. stainless steel? Or plastic vs. aluminum reflectors? There is no excuse. Also there is no excuse to advertise CREE XP-L when it actually is chinese manufactured inferior LED's. The advertised specs are always superior to what it actually is.
I recently purchased the red version of the Cree XM – L2 T6 2400lm Diving Flashlight When it was up for offer a few months ago.
Is it normal for the batteries to drain on them after a few days? I wondered if the magnetic switch keeps a certain amount of current flowing even when not in use.
Well, a mag switch is really working like an e-switch, so depending on the driver design, there will be parasitic drain. Sounds like your light may have a fairly high parasitic drain unfortunately. Some guys here know how to measure it - I don't, but I know with our custom firmware we are using now on the ATTiny13A MCU drivers, we ensure the parasitic drain is as low as we can get. Pretty sure typical run time is in the months on standby. Always good to have a "lockout" feature in the light. For those lights that do, a slight twist of the tailcap will break the connection and eliminate parasitic drain. Lights like the ZY-T11 clones have this feature, as well as the SupFire M6 (ultimate soup can), etc. That's why these two lights are on the top of my all time favorite list of lights to mod . Also up there are lights like the Warsun X60, Yezl Y3, or pretty much any light with a side e-switch that also has a tail-switch that cuts off power -- works same way as the "lockout".
For dive lights, I recall reading here on BLF a diver saying he always re-lubes the threaded connections on his dive lights after each day of use. If you do that, then might as well pull the batteries between uses as well, or at least remove the tailcap.
Don't quote me as recommending this light, but back on topic, this light: gearbest.com Sharp Eagle - Warsun look-alike looks outstanding at that price. It appears to be a re-branded Warsun X60 for $20 - great deal, potentially, if it's the real thing.
GearBest - you guys should be informing us of this deal for sure...
Also would be just a little worried that if they can't get the power-button aligned straight on the photo-shoot sample, then what hope do we have for a good example? Plus even the surround looks a bit dinged...
I ask because GearBest has been more responsive than any other supplier to actually getting information to and from the people who make various flashlights.
Hi Tom E, thanks for pointing out it, we have moved the “SS bezel” discriptions, beg your understanding, as we have thousands of items, and will miss something.
If you’d bothered to READ that thread you’d have seen what’s in it.
The member who has this light has asked the same question.
I had already mentioned there that I’d asked you here — and on the questions page at the sales site.
We have the same question.
He also wants to know how to take the emitter out.
That’s why I asked you for help with — how to open the light to be able to change the emitter.
I asked you because your company sells a lot of the “Sharp Eagle” lights.
Who can contact someone at Sharp Eagle who would know how to open this light up?
...along with a couple of other SKUs of similar bulbs and was disappointed. I wasn't expecting a full 18W, but these actually run at 4W, less than 1/4 of the rated specification. They ended up allocated as lighting for a closet, but only with a 2-bulb splitter to get enough light. Far too dim for my intended application.
I hope these SKUs perform better than what I received.
Ok, I see that change, thanx! But, it still says aluminum smooth reflector when in fact it's a plastic smooth reflector. Can you correct this as well?
Just please, please note that all your Sharp Eagle branded lights seem to have some level of lies in their ads on your site, and always, always the lies are slanted towards being better than it really is. It's not a simple mistake -- it's intentionaly to lie about the product being better quality than it really is. The rule is pretty simple - anything the customer can't tell 100% certain from a posted picture is fair game to lie about. Apparently GearBest can't inspect every new product they add to their listings, because if you could, it's quite apparent. I'm sure you simply post specs provided by the supplier.
Actually I'm impressed with GearBest listening and attempting to address these issues, other vendors such as TMART, DX, and FastTech seem to be totally ignoring our comments on these issues. Thanks Again!
