So I bought 4xAA and 4xAAA "OEM Energizer Ultimate"s from eBay (for future reference: dealer is shinee2010).
They are really light and they all read ~1.75v (I'm not at home so I can't weigh them or test them otherwise).
How can I test their capacity?
I can test the current they deliver and see if it follows the curves that Energizer shows for the Ultimates, but other than that - Can I try a discharge in my AngelEyes charger? Will it reject the batteries or report incorrect capacity? Will it explode?
Seems like a good deal to me, but I dont know what it is lol. Lithium batterys with 1.5V? I didn't know thats exist. Looking forward for some information.
Edit: oh I guess they are not rechargables.. damn! So don't put it in your charger ;) at least I wouldn't
thanks for heads-up!
Here, lithium primaries are around 2EUR/piece, so might just test these.
Not far fron the price of alkalines, surely these cannot do worse…
Very interesting. From what I've been told Energizer had a patent on the AA primary "advanced lithium" and "ultimate lithium". Just like everything else, It was only a matter of time before someone, somewhere got around that. I would love to see a test of these compared to the real thing.
This flashlight is regulated and it just instantly reduces the light output when not enough "juice", it doesn't decreases in output. So the results at spot on.
I wonder how these "OEM" ones are. Maybe I'll buy a set and compare the results.
I believe there is somewhere a quite accurate runtime chart from
Zebralight SC51 with L91 Energizers? Does anyone find it?
I could do a runtime test with Zebra, since its about the only quality AA light that I have and which I believe has quite constant quality and good regulation for Li-ion primaries also.
The OEM Ultimate weights: the AAA weigh about 7.2g each (three are 7.2g, the fourth is 7.4g), the AA weigh about 14.7g each.
For comparison, Energizer states that the AAA should weigh 7.6g and the AA 14.5g.
The AAA and two of the AA are about 1.8v, the two other AA are 1.7v.
They give very nice current through them - I tested first on the junk DinoDirect free flashlight which is a 2AA with generic LED and a boost driver, and it draws about 1.8A with crappy alkalines, 3.2A with GP ReCyko+, and 3.5A with the OEM Ultimates sagging very quickly to 2.98A from there dropping very slowly. The voltage of the batteries dropped to about 1.6v after this short test. Next, I did a 1 minute test during which the current sagged from an initial 3.2A to 2.7A, and the batteries which started at about 1.65v almost didn't drop voltage - they ended up at 1.6v. I didn't run any long test as the junk DD light just gets warm too fast - after the 1 minute test the host was about 35 degrees C and the light over 42 C (from an initial 30 C). Energizer states that maximum discharge rate of the Ultimates is 2A, so the above readings are about 50% higher than the specs... very strange.
Next, I tested the AAA with my Manafont Ultrafire 3-mode XM-L inside a Solarforce L2i host. Fresh crappy alkalines gave 0.8A on high. GP ReCyko+ gave 1.2A. The OEM Ultimates gave 1.6A which quickly sagged to 1.4A. Combined voltage dropped from 5.3v to 4.8v. A 1 minute test resulted in constant 1.4A current throughout the test, and combined voltage dropped from 4.8v to 4.7v. The 1.4A current is very close to the max discharge rate stated in Energizer's datasheet of 1.5A continuous.
So all in all, I'm quite impressed with these batteries.
If their capacity is as advertised, they are extremely good buys for primaries and much cheaper than the Energizer branded version.
