Hi all,
Thanks to this den of addicts helpful support group, I think I’m ready to start my first mod. I have most parts on hand, and a ready host in my stock Thorfire C8s. I’m happy with the build quality and throwing intensity of this light, but the tint is pretty cold for my liking, and there’s a slightly annoying ring around the very outside of the spill. I also wouldn’t mind if the hotspot were a little bigger, even if I have to sacrifice some lux/throw. (I realize these lights were designed to be throwers, and I like checking out the far side of the field behind my house, but I’m not looking to create a pencil beam.) Finally, I’m ready to start playing with something!
Ultimate goal is to get this light to a good neutral-warm tint, as bright as possible, without narrowing the current hotspot.
To that end, I’ve purchased a few goodies:
- Qlite Rev.A 3.04A 8*7135 driver with Guppydrv from RMM
- BLF A6 driver from Banggood (not delivered yet)
- XM-L2 T6 3B
- Nichia 219c
- Spring bypass “gootwick”
- 20ga silicone wire
- AR coated glass, C8 OP reflector
My questions:
- Are there any combinations of emitter + driver that I should avoid, or should I just mix & match until I’m happy? From what I can tell, both the XM-L2 and 219c are happy with plenty of amps, so both drivers should be “compatible” with either emitter, and I’m not in danger of pushing too many amps. Am I missing anything there? (FWIW - most of my 18650’s are old laptop pulls, but I’ve recently picked up a Panasonic NCR18650PF and a Samsung 26F, both from RMM, for potentially higher outputs.)
- Does it matter what order I do mods? I.e. is it important to do a spring bypass or replace any wires before adding a more powerful driver?
- Anything I’m missing, or should I just jump in? Pretty sure I know the answer to this one (
), but I thought I’d check to be sure I’m not making any rookie mistakes that are going to fry something right off the bat. :~
TIA!
(Edit: Leftover parts aren’t a problem - I have a Thrunite Neutron 2A that needs a new emitter, a small 4xAA lantern with a tint that’s way too cool, and a few other ideas…)
