Any questions/chatter relating to the give away, please leave them here, I’ll be happy to answer and it makes the give away easier to manage. :bigsmile:
Thanks for the opportunity, Gords!
So I can troll here. :D
Why the _k not? It’s only any use till the give away ends, have at it. :bigsmile: ![]()
See Orion, your getting the hang of it, you could just drop 70 posts in here…. I’m bad really aren’t I… :bigsmile:
Well I need 5 more posts. 4 if I post my 150th as an entry in your give away. ![]()
Orion ever heard of resizing pictures? ;)
Scaru, ok replaced it with a smaller pic. I guess pacbough shrinked it and saved it on photobucket or something?
No you can do it all from BLF. So start with a obscenely large picture like this one.
Then you put the URL of the picture in the Image URL space. And then under the appearnace tab you put 100% (or any other percent) in the first box and then make the second box blank. So now it is tiny. (Or big if you want)
Note: You must be using the Advanced Post Editor
If you open your image and mine in a new tab, Orion. You will see that they come from the same source.
Can I increase my post count here?
Well…can I? :bigsmile:
I believe you can.
Just post a few more times and you can find out. ;)
Yes.
