Hello, guys.
Cyansky P25 V2.0 outdoor flashlight Micro-arc Oxidation Version is available today!
:question: What is micro-arc oxidation?
Micro-arc oxidation (MAO) is also known as micro-plasma oxidation. In the process of micro-arc oxidation, the base metal reacts vigorously with oxygen ions and electrolyte ions under the joint action of thermochemistry, electrochemistry, and plasma chemistry, undergoing melting, eruption, crystallization, and high-temperature phase change process, and finally fusing on the crystal surface and sintering to form the ceramic layer.
The ceramic layer has a dense structure, good toughness, wear resistance, corrosion resistance, high-temperature impact resistance, and electrical insulation properties.
In general, flashlights treated with micro-arc oxidation are more resistant to wear and corrosion than hard anodizing.
:question: What about the product?
Product features:
1*CREE XHP 70.3 LED
All-metal design.
Micro-arc oxidation surface treatment
White light multi-mode design
ECO/Strobe/SOS mode
Wider angle floodlight
Max. 3600 lumens & 208 meters
Tactical Double Switch
Intelligent temperature control
Power indicator
Memory function
IPX8 waterproof, 2 meters impact resistance.
Working temperature: –30℃ to 50℃.
Click here to know more about the Cyansky P25 V2.0 MAO
We will offer a 15% discount to the BLFers of this product. Limited quantity, while stocks last.
Discount Code: SPECIALFORBLFERS
The discount is valid from now until July 27.
:question: Review:
Check the review by FLASHAHOLIC
*【Giveaways】*If you have any thoughts about this product, please leave a comment below. We will randomly draw 2 lucky winners in the comments on July 27th to win our Cyansky P25 V2.0 MAO version.
Good luck. ![]()
