In response to user feedback, we have upgraded Torcheye to resolve the issue where light and screen placement on the same side caused eye glare.
Tired of “low battery anxiety” or carrying extra tools? Meet GODYGA TorchEye RD.
We’ve engineered an EDC clip-on light that outperforms the standard competition:
0s Emergency Turbo: Instant high-output access, even with low battery.
Laser Distance Meter : Built-in 65ft measurement for work & DIY.
Smart Display: Real-time battery % and runtime tracking.
Built for contractors, outdoor enthusiasts, and EDC pros.
GODYGA, Go Dynamic Gears!
Upgrade your gear. Shop Now: [https://amzn.to/4vUudnh]
15% OFF Code: GODYGAX1
https://go.godyga.com/TorchEye
Free Shipping
Does it also do measurements in metric?
@GODYGA Please note that I have moved this post the Commercial Sellers' Spot category. Please do not create additional new threads, and carefully read and obey the Rules for Commercial Sellers:
https://budgetlightforum.com/commercial
Yes, it supports both metric and imperial units. You can switch between meters (m) and feet (ft) depending on your preference.
Stop guessing in the dark. With built-in laser measuring and real-time battery life tracking, you’ll navigate driveways faster and size up packages instantly. 0-second full 650lm brightness when you need it—keep your deliveries moving.
Perfect for Amazon Flex, FedEx, UPS…
Upgrade your gear.
Shop Now: https://amzn.to/4vUudnh
Amazon/GODYGA Official Website
Free Shipping
TorchEye UDa is crafted for renovation workers, delivery men, EDC lovers, outdoor enthusiasts, and tech lovers.
Discover the key features:
· Face-Safe Lighting (No more blinding yourself while checking the display)
· Professional Laser Distance Meter (20m/65ft range/±3mm Accuracy)
· Family Height Tracker: Angle compensation tech ensures accuracy even when tilted
· Quick area measurement function
· Professional Angle Measurement (0–360°range/±0.3°Accuracy )
· 650lm White light
· 800mW 365nm UV light
· 5–650lm Stepless dimming
· BMS Zero-Delay Bypass Turbo
· Smart Display : Real-time % battery and runtime per mode
· Solid A6061 CNC aluminum with wear-resistant hard-anodized finish
· IPX6 Waterproof
Upgrade your gear. �� Shop Now: https://amzn.to/49RaqvO
Amazon 15% OFF Code: GODYGAUDA
Charge and Use Immediately,650lm Maximum brightness even at 0% battery level.
White Light: Up to 650 Lumens and 120m beam range.
Red Light: Up to 175 Lumens in steady or flashing options.
Smart BMS Protection: Fully in just 1.5 hours from any USB-C device.
Lightweight and portable: Weighing just 54.2g (1.91 oz) and measuring 59.1mm (2.32 in), the magnetic base and pocket clip attach.
Charing time: About 1.5 hours.
Click “Shop Now” to grab yours before it sells out!
The future of lighting is here:Amazon.com: Godyga TorchEye R Smart Display EDC Flashlight Clip-on Light, 650 Lumen with White & Red Light, Real-Time Battery & Runtime Indicator, Type-C Rechargeable Magnetic Flashlight for Emergency, Signal : Tools & Home Improvement
15% OFF Code:GODYGAX015
#Godyga#TorchEye#clip-on flashlight #edcflashlights #edccommunity #techlover #edctools
Hello @GODYGA , please carefully read and obey the Commercial Sellers - BudgetLightForum.com rules.
I have moved and consolidated your recent posts into two (2) threads:
- GODYGA / TorchEye product promotions and updates
- GODYGA / TorchEye design discussions with the community
Please do NOT create any more new threads. Instead, you can post product updates or design discussions in your threads that already exist.
