Thanks to this list, I have learned that the top recommendations are not the best for NiMH! I used to use those chargers and have destroyed more cells than I care to mention due to my ignorance and the way those chargers work. I no longer use dumb chargers like the energizer ones above. Stick with a smart charger like the one in my original post or the tenergy one he recommends.
If you already have a good li-ion charger (and WP2 is quite good IMO, have one personally), I’d suggest you NiMh charger only. And for that budget, BC700 is one of the best AFAIK (have one of this too :bigsmile: ). For 20 bucks more you have best chargers, i.e. Maha 9000 or BC1000 (but BC700 is better bung for the buck). Check this thread also.
if 30$ is the upper limit and you live in the US, then i'd buy the BC700 (BC means battery charger i guess lol, i dont have it but it's the most sold NiMH charger with LCD display on the planet) or try to find a used C9000 (C means charger i guess ;) ).
The C9000 is more powerful than the BC700 because 9000 > 700.
Two things you want to look for are: 1) "Smart Charger" - means it monitors the battery and stops charging when it's completely charged (as opposed to the usual "dumb" chargers that are timer based and can "cook" cells after they are fully charged). And 2) Able to charge single batteries (i.e. single-channel) so you're not stuck charging in pairs. If you have a 3 cell device (3AA light, 3AAA light, etc . . .) it's tough to charge the batteries in a 2 or 4 cell dual-channel charger
I bought the AccuPower IQ328 from Ebay (see thread here). I believe it's a BC-700 clone, however it does discharge tests at 500mA whereas the BC-700 only does 350mA (and only charges at 700mA max compared to 1000mA for the AccuPower). I really like mine. I also heard the BC-700 capacity tests come out higher than "true" (see the charts at the Ebay link - but I also read/saw this elsewhere).
If you don't want to discharge test your batteries, or don't need a high charge rate, go with the simple Sony. Only issue on the Sony is that there is only one LED, so you can't tell when individual cells are done charging.
lol, that is quite a dumb comparison, my friend :bigsmile:
BC1000 is very similar to C9000 (tech specs), but much smaller/compact. Could be good or could be bad (because of the size, C9000 has better heatsinking, for example). 40 bucks for C9000 is an awesome price (unless you need to pay 15 bucks for shipping :bigsmile: )
