You can’t go wrong with a Shining Beam I-Mini. Built to take a beating. Made for Shining Beam by Olight. Mine went through the wash the other day and worked perfectly right out of the machine. $25
Can’t comment on the battery,
These two lights are worth considering:
$14 Small Sun ZY-C1 Looking for 16340 light
lots of throw
or
$17.50 Trustfire Mini-01 (closed,all sold out) another batch of BLF Mini (TrustFire mini-01)
as a keyring light, and the group buy made it one of the most popular around here.
TF Mini-01
I have an Ultrafire 602C which is a decent one mode xp-e light.
http://dx.com/p/ultrafire-602c-q5-5-mode-led-flashlight-cr123a-10806
The DX version linked is apparently 5 mode. Cheap, throws decent and tailstands. The Mini is a better value though.
My two favorite 16340 lights are the Nitecore EC1 for throw and the Eagletac D25C clicky for flood. Even with lower output I like the modes on both better with cr123 batteries.
I might have to do a 16340 roundup if I get time.
Trustfire flames would be your best bet for cheap batteries.
I’ve used the K-109 some 2 years ago. Actually, quite a good small flashlight for its price. Only the Emitter is outdated.
I would rather recommend the following: Eastward YJ J08 or UltraFire 123A
XP-G and XM-L are much more effective, compared to XR-E…
But if you are looking for a really cheap CR123A/16340 flashlight, You can also look at these: Romisen RC-C3 and Romisen RC-D6
D6 even has a magnetic tail - useful feature.
I think Boaz has some let perhaps? Maybe PM him
Why pay more for comparative quality, more weight, and modes ya don’t need? I should know. I bought bulk. One of the best bang for the buck EDC’s out there IMO.
This is the shizz………….
Xtar wk21 is awesome but slightly over your budget
Depends what you are after. An RCR/16340 light is generally wider/fatter than an AA, but can be shorter.
An RCR has similar capacity to a 14500, so fairly equal in runtime/performance. The main advantage is if you swap to primaries you get 3.0v instead of 1.2/1.5 that you get with an AA.
Does it need to be really small?
Solarforce L2M has a stumpy mode with allows 1x16340 or 1x18350 to be used. Combined with an XP-G or XP-E emitter you could get quite nice light and runtimes out of it with a fair amount of throw for a compact light.
As for cells, I highly recommend quality cells. My AW 16340’s easily out perform my DX Trustfire Flames 14500’s, despite the Trustfire’s supposedly having more mAh.
Thrunite T20
It states to not use 16340 but i have been using with not problems. Very compact light.
I have the Akoray K109, but my one uses CR123, I use AW cells, as was told they were good, to be honest not impressed with AW cells though.
The light itself is great, really tough, has often been inadvertantly treated roughly but hasn’t missed a jolt.
I don’t like the amount of modes, it has slow strobe, double fast strobe(2 flashes) high, medium, low, though I can forgive it as it has mode memory.
It is very bright for it’s size and cells last a long time, even when used on high.
As I like also simple flashlights I also have a Ultrafire MCU-C7, it just has strobe, high and low.
I got both of these from DX, but a search today says not recognised ?
I whole heartedly recommend the akoray k109 though, one of my fave CR123 lights, I have Fenix P1 and P1D, but prefer the 109 to be honest, maybe not quite as well made but perfectly acceptable, and does the job intended, putting out light rather than looking good.
You absolutely have to go with the TrustFire Mini 01! In fact, Rey (WWEFANS), should still have some of the BLF editions available from the second batch. They are 3-mode with no blinkies and a great low and great high. It's a must have if you are using 16340, ;)
The Trustfire protected Flames are great cells to use as long as they are genuine.
What sort of issues have you had?
My recommendation is the Ultrafire 501a; it's a basic P60 host sized for single CR123a/16340/18350 use. The empy host is here at Manafont for $5.89:
http://dx.com/p/5-mode-led-driver-circuit-board-for-flashlight-dc-2-8-4-2v-106796
Combine this with an Ultrafire XP-G R5 dropin:
Single Mode: $9.85: http://www.manafont.com/product_info.php/ultrafire-cree-r5-mode-led-dropin-module-42v-18v-p-4051
...or 5-mode here for $10.05: http://www.manafont.com/product_info.php/ultrafire-cree-r5-5mode-memory-led-dropin-module-42v-18v-p-4052
... and a pair of good protected 16340 Trustfire Flames for $6.07: http://www.manafont.com/product_info.php/protected-trustfire-16340-37v-880mah-rechargeable-batteries-flame-2pcsset-p-5571
That gets you a very nice compact 16340 light for $16.00, ($22 including cells). This light is very bright for its size and is easily pocketable. The XP-G R5 drop-in is driven mildly enough that it won't be an excessive load to dramatically shorten the life of your cells.
I really like mine!
+1 for BLF MINI. Great little light.
I would never use a 501 2 4 or whatever for a backup…they are so cheap that you are not save for a fail…
If you want a p60 style then solarforce is the way to go. There are host available for 10$ up from solarforce sales itself. The mini can be used with one cell the others with 2…
I have the mini01 too and I am very impressed and use it as esc on my keys…
I also have an c60 fromm wallbuys on its way to me, fairly cheap 7$.
Not so much “issues”, they just to me don’t seem to have much guts/performance, my Ultrafire BRC seem to have better staying power.
I’ve not done any actual testing of them, I bought the SAW from a respected seller on CPF, they also seem to lose power quicker when not used than other so called inferior cells.
I’ve recently ordered some ztar and pana cells so will see how it goes with them.
On my single 18650 light, it seems the really bright only lasts around 30 secs or so regardless of which ones I use, but again the lowest time is with AW, I have I think 6 18650 AW, and around the same CR123, but the 123 seem a lot better size for size sort of thing.
Sorry but you've already asked this question and it's a bit rude to ask it again in another thread and then act like no one is helping you .
No one? I can’t be the only one trying to use 16340
https://budgetlightforum.com/t/-/13428#node-15740
buy something and figure it out
Making a mistake will help you learn for yourself it's not lifethreatening and there is no right answer ...so ... buy something that you like the looks of ...why not just buy the surefire one you linked to ..and then you can be a surefire fanboy..
Or
you can wait until everyone has posted every single cr 123 light ever made:P
tank 360
itp
martac
eastward
romisen
nitecore
sunwayman
hds
There is no right answer ..buy the light you like the looks of first ...if it's flawed ...fix it ..
No matter what is wrong with a light it can be fixed ..BUT if the body sucks or isn't what you want or like ..it's like kissing a big fat ugly chipmunk ..it ain't never gonna be right ..
Get the body right first ...no one can tell you what appeals to you that's up to you .
Ha! I knew I had answered a similar question recently!
I’ve decided on a light
Saw this pop up on DX’s ‘New Arrivals’ about 2 weeks ago. (Bear with me, this is my first review so if I miss anything obvious or not so, do flame away.) http://www.dealextreme.com/p/new-10b-cree-q5-3-mode-310lm-white-led-flashlight-w-strap-black-1-x-cr123-or-1-x-16340-123406 Impulse buy: The worse kind. Maybe every kind of buy here. Anyway, I just got it and I must say I’m duly impressed. I expected poopyness and I got whoopyness instead. The finish, performance, size/handling characteristics…
Just want to make sure I get good batter and that they fit!!
So these
http://www.manafont.com/product_info.php/protected-trustfire-16340-37v-880mah-rechargeable-batteries-flame-2pcsset-p-5571?rp=032201
Or
http://dx.com/p/ultrafire-3-6v-880mah-lc-16340-protected-cr123a-battery-2-pack-3273
