Yep just a 12V sealed lead acid battery 5Ah, a car high beam, and a 10A toggle switch lol no rocket science here …
I was just on that page I think; Illumination supply — has 3 of those mounted to a pcb but no heatsink … hmmm .
That flood looks interesting Djozz, got a link ?
http://www.fasttech.com/products/0/10001074/1092400-20w-1800lm-warm-white-outdoors-flood-light
Here is one, but search the internet on 'led flood light' will give plenty results. They are usually rated at 110-220V though, not sure what voltage the actual led runs at. Perhaps it is still easier to start with an actual flashlight.
Edit: found a 12V version:
http://www.amazon.co.uk/gp/aw/d/B0075KK2UQ
Hmm… can’t seem to find the same one at amazon us as yours at amazon uk … will keep looking …
That’s way too nice to see chicken poop and mud all over it in less than a weeks time lol …
PS-I forgot to mention that it needs to be easy to clean, shockproof and weatherproof too (she has to go out in the rain sometimes )
PS#2 - I did find this one on amazon; 12V 3500K :
htt p//www.amazon.com/QUANS-Floodlight-Waterproof-Outdoor-Garden/dp/B00EH4ANV6/ref=sr_1_1?s=hi&ie=UTF8&qid=1387842131&sr=1-1&keywords=3500k+12V+floodlight#productDetails
At 12V/ 0.8A I’ll get a lot more battery life than drawing 5A heh … Might even be able to run some 18650s in series instead of those heavy-assed lead-acid monsters heh …
I’ve looked at the Kung … are any of these warm-white about 3000-3500K ?
Find one with a tripod thread and mount it above the dynamic lifter:
Nice looking rig. Picture it covered in chicken mud tho …
I like the handle on the top. That’s exactly what I’m looking for .
Not that I know of but someone could probably mod one for you, There is a member on here named Old-Lumens who is modding a King or Kung right now, PM him and he could probably build one for you and put whatever LED you want in there. Old-Lumens King
With the Litebox you can easily put in any tint bulb you want, probably already has a ww in there and has a base for sitting it down on the ground.
Blackshadow Terminator with a tripod?
Oh, I didn't think of that. The SRK's and Kungs are not water proof. Also, would probably not be easy to clean.
:Sp
Yeh I gotta wipe the crud off fairly often … blaugh … :Sp
Oohh- the Blackshadow comes in neutral white … may have to snag one of these for meself —
(and let the wifey use it on a limited basis hehe )…
Neutral is not the same as warm, it’s in between cool and warm. Sure you know but you were wanting warm.
Roche M170 with a tripod?
Just give it a quick hose down after.
I use it to go crabbing, it doesn't mind the mud and water at all.
Perhaps you can slowly ween your wife away from the silly yellow tint into the dark side... or rather the extremely bright 1A side.
The two neutral white multi emitter lights suggested (Blackshadow Terminator, or M170) should help this along. :)
—post deleted — due to pui (posting under the influence)
You can always dedome. 1A -> 4D
XP-G2s are the nicest de-domed tints I've seen so far, almost as nice as the warm MT-G2s
Search Ebay for “10w led floodlight warm 12V”…
Here’s one from a US seller for $12.50 Runs off a 12 volt battery (only the 10 watt units run off of 12V). Make sure you select warm white…
