Ostensibly this should be an upgrade over ArkPro Ultra, but it’s got a major drawback. Olight has been adding more and more features and cost with every Ark-generation. I think they’ve reached the point of diminishing returns with ArkTac Ultra.
It adds an excellent main tail switch, great proximity sensor, red light, glass breakers, a questionably-useful secondary tail switch, a weird pocket clip, and one major issue: you can’t select between spot/flood manually. ArkTac has spot beam that’s perfect for everything, but forces you to use the way-too-floody beam most of the time. With that issue, the sky-high price tag, and the built-in battery, this one is hard to recommend.
Great review and thanks! I was asked to review it, but passed. I figured after reading the specs that this ine wasn’t much of an upgrade over the Ultra.
I also have the pre-release version and very similar thoughts. I absolutely love the main tail switch and find the red switch pointless and somewhat hard to use.
The one thing I do want to point out is that the tint appears to be much more neutral on these ArkTacs than on the normal high CCT Olights. Mine is at or below BBL in all modes (including when the spot steps down to the second highest level). My flood measures -0.001 DUV on low, -0.002 on medium and -0.008 on high. Spot measures -0.005 on turbo and 0.000 after the step down.
So between the improved tint and the tail switch, I think it’s a nice light. But I don’t like giving up choice between spot and flood.
Separately, I don’t find the red beam to be as useful as a separate flood/spot. We’re seeing more and more red beams in lights and I don’t really find myself ever actually using them. UV and Laser are differentiated but red just feels like a moonlight substitute. I think it makes a bit more sense in a headlamp but I don’t see myself using it handheld.
The red light is one of the things that attracted me to the ArkTac, I would find it more useful than a laser or UV. I was hoping that the red button could be used as a shortcut to low red, but that’s not the case. That, no longer being able to choose between spot and flood and having reservations about buying another light with a non-replaceable battery killed it for me.
One big problem is the battery. Not only is it captive, but it’s extremely difficult to remove and the cost of a proprietary battery replacement makes it more sensible to buy a new light. That’s such a waste.
