Group Buy-BLF X6-SE OP update-GB over.
Amen !
I know, I had already read all the posts of the last few days. But it seems everything is at least pretty decent.
If it is easy to make it even better (like using the R025 instead of the R030), that would be very nice.
On one side I’m tired of waiting and on the other side we have been waiting this long, a bit longer is not too bad either.
I guess I’m happy anyway :slight_smile:
(As long as that Christmas tree is not included)
Guess that’s the “side-effect” of Lo to Hi UI. Didn’t like Lo to Hi mode change, but the step back up to Turbo, along with mode memory, makes for better operation for me than I imagined. Thanks.
Is this the highest discharge protected batteries at the moment?
The Panasonic PF (2900mAh) and PD (3200mAh) are both rated for 10A. Protection circuits does not go that high though ( which is not relevant for this GB light).
RMM also sells the newer PD version. Or you can pick them up from BG. Coupon code: ENCRBD =19,1$ for a pair with free worldwide shipping. (or pay more for single cell orders)
Its the best high discharge high capacity protected cell I know of. Im not aware of any of the even lower resistance cells with protection circuit.
Cheers, just ordered 4 of them to keep as spares.
They obviously won’t perform as well as unprotected high drain PF’s will they? I normally use those in my Vinh lights.
In short, it depends on the light.
The slightly longer version: If its properly regulated your will get similar performance but longer runtime with the protected BD cells (due to the higher capacity), unless the drain is so high that the protection kicks in. Which most light will not be capable of.
If output is depending on voltage then the unprotected PF cell is a bit better. How much better will depend on the current. Visually not a big difference.
If vinh have done his homework he should be able to tell you on each specific light how it behaves before and after the mod. I doubt you are going to get the full story from him, or that he even knows on all lights. In general he does not have a habit of mentioning the downsides of certain mods. Highlights sells better.
Yeah…true.
These might become my new protected batteries, I’ve always used NCRB’s up until now.
Thanks for the detailed explanation.
Final specs for the BLF Special Edition Eagle Eye X6-SE:
> 4 modes with last mode memory. Mode spacing as follows:
> Mode 1/Low/Moon ~5 lumens.
> Mode 2/Med. ~250 lumens
> Mode 3/High ~600 lumens
> Mode 4/Turbo (~3.3 amps with 3 min. step-down to High) ~1000 lumens
> Copper MCPCB w/DTP (Direct Thermal Path). Excellent, high quality board from MaxToch.
> Improved lens (Double-sided/coated AR lens).
> No glue on threads.
> Driver voltage range: 3v-4.2
> Reverse clicky.
> Matte black HA III anodization.
> “BLF Special Edition” custom logo on one side, Eagle Eye X6-SE logo on the other side.
> Gift box with BLF graphics.
> Two tint choices: XM-L2 U2-1A or XM-L2 U2-3C.
> Comes with: Adjustable Lanyard with quick-releasae, clip, extra button (GITD) and 2 extra O-rings.
> Reverse polarity and low voltage protection.
Final pricing: $19.99.
The first production run of 500 units should be finished around November 5th. We will release the GB code to BLF members that committed to the first 500 units around that time. We don’t want to release it too early in case of production/shipping delays, which would obviously end in paypal disputes, etc.
I will have more info on GB instructions in the next few days.
Thanks!
krono
(Updated also in OP)
Thanks krono for the time and effort you put into this!
The Group buy list hasn’t been updated in a while, but I think we’re close to 750. So even if they do 2 runs of 1000pcs total, there would be absolutely no problem in selling the remaining units. The final specs are crazy good for the price and I doubt there is a better light under $20.
Sadly my number is after 500, I guess I’ll have to wait.
let the ‘feeding frenzy begin’……
Nice, glad I’m on the list for 4 still all before #500!
In case anyone is wondering, the MCU on there is a PIC 12F683, that means any other SOIC8 PIC can be swapped on (all soic8 PIC’s share the same pinout’s). That means any of the existing clicky FW’s for PIC can easily be used, the most editing it will take is swapping pin assignments for PWM out and the vdivider input (if equipped, it may somehow use the internal reference for voltage monitoring on 1 cell)
Hooray, finally getting moving! Thank you Krono!!!
Good specs!
I think they need to gear up and make at least 1000 or more units…these WILL be going fast!
And at $19.99 w/ pretty much ALL custom made hotrod out of the box setup
It’s like getting a Dodge SRT or a Ford Raptor for the price of a S-10 or Ranger!!!
Yup…for that price and everything in it…these will be incredible!
Awesome group buy :slight_smile:
Did someone confirm this driver won’t handle 8.4V? Maybe not in this configuration, but generically?
It seems the same driver that was 8.4V compatible.
A short video showing an X6 with NW beside an X6 with CW. The CW is this sample, the NW is one I’d gotten a while back that is running 7 levels, in this video it’s on level 6 which is about 930 lumens so it compares favorably to the sample on Turbo. (This X6 with NW pulls over 7A for 1667 lumens on level 7, by the way)
How can you tell you’re a BLF mad modder? You discuss how to tweak out an already hotrodded factory light even before they hit the streets :slight_smile:
Awesome!
I wish thats how they worked, its like stepping into the twilight zone, whats easy for you is impossible for them, and what makes no sense to you is childs play to them
I am dismayed that no one has seen an actual AR coated lens for this light yet, i’m willing to bet the final light won’t get it (what is the size of the lens, i want to see if i can find one somewhere)
flashlightlens.com has their UCLp that is awesome in this light. :wink: About $5
Hey! Easy there! I drive a Ford Ranger.
edit: I would like a NW with 7 levels and a high output of 1667 lumens! How much extra that cost me?
