Just keep ordering a few a week, then for some reason they just keep arriving so steadily it never seems like your waiting more than a week, even if your using slowtech!
The problem with that one mike, will be that to drive it to a reasonable level, even dedomed, will fry your hands and runtime will be poor.
I bet it will be driven around 1amp per emitter, and the reflector appears small. I bet a c8 will out throw it, but of course the lumens are what the real selling point. Good for walking through bush etc, but not good at range.
If you want a good cheap thrower, try the BTU shocker dedomed. Mine has about 500,000 cd and absolutely dwarfs my 160,000 cd sn6.
Had a play with the 2s last night, dedomed but stock otherwise. Its a good torch, its like 2mm smaller than the 2x so I dont understand exactly the point of offering both, but man I cant wait to get my 4 here.
Sorry, no. I got a ton of PD's still, and the PF's look to be rated at higher resistance - not too excited bout them. I know I got a couple of PD's with the solder blob too, so must have had troubles with flat contacts - not sure if it was from being in series or flat contact board.
Well, small magnets on the + end, or between cells is a bit risky. Not sure if solder is any better, but the typical Chinese magnets aren't too good for conductance when you want to keep resistance to a min.
I’ll have to check to see if there is sufficient clearance to add a shrink wrap tubing wrapper. If so, I can make a small copper pill to go on top of the cell and lock it in place with shrink wrap. That should work.
I heard most parcels are in Singapore, waiting for transportation.
I double checked with our shipping center. Now there are many parcels piled in Singapore. Parcels quantity is booming as Christmas is approaching. The delivery is indeed much slower than before.
I will keep tracking these parcels. If anyone can’t track the parcel, let me know please. I can do it for you.
