✅【 GROUP BUY 】Rovyvon S3 - Triple XPG3 / Nichia 219C 1800LM Mini EDC Flashlight * 【 INTEREST LIST 】
✺ Rovyvon S3 ✺
Triple XP-G3 / Nichia 219C
Group buy price - $**.99
Description
A triple-LED EDC (Everyday Carry) Flashlight and the optical Lens from LEDiL®, max output up to 1800 lumens, powered by 16340 Li-ion and CR123 battery, here is the Search Series S3.
Its body was crafted from aluminum weighs 78g/2.75oz with the battery and pocket clip included. It's super bright for its compact size of 69.6mm/2.74" long and 24.8mm/0.97" in diameter. The LEDs have two options - 3x CREE XP-G3 Cool White (Max 1800 Lumens), higher output and less CRI, or 3x Nichia 219C Neutral White (Max 1200 Lumens), lower output but high CRI.
As an EDC light, a deep carry pocket clip is a must, on the clip, there's also a 1/4" tripod hole to be able to install as a fill light. Move to the tail, it includes a USB-C charging port that could fully charge the light in 1.5 hours, a lanyard/paracord hole to carry as you like, a tritium slot to install a glow bar, and a ceramic glass breaker.
Features
  • Equipped with 3 LEDs, max output up to 1800 lumens*
  • Optic lens from LEDiL® from Finland
  • Uses 16340 Li-ion rechargeable battery, compatible with standard CR123 battery
  • Max runtime of 22 hours when working at low mode
  • USB-C rechargeable, fully charged in 90 minutes
  • New designed deep-carry pocket clip
  • 1/4" tripod hole built into the clip
  • The tail cap is removable to replace the battery
  • Lanyard/Paracord hole, Tritium slot, and Ceramic glass breaker are integrated on the tail cap
  • IPX7 water resistance
*It will step down to 500 lumens in 3 minutes when it works at the max brightness mode (Cool White Turbo, 1800 lumens)
If you are interested notify in this thread (not in PM)
My thread:
⭕ BangGood.com Deals
RESERVED
Interested …
Interested in this one.
Interested
interested
Interested
Sure
Interested
Interested
Interested
Interested
Interested
Interested
Interested
Interested.
Another light that could fit 18350, but for some unknown reason, the manufacturer chooses 16340…
Given the structural options RovyVon took to build the light (charging on the tail / electronic signal), making it usable with 18350 would make the flashlight bulkier/larger in diameter.
A different strategy for that would be needed, eventually putting charging port on the side/near the head.
Interested
replied all
