Update
Code available!
please send a mail to m4dm4x@aon.at to make answering less painful...
include your nickname ;)
Hey!
another great light is on the way:
Features
• 4th Generation KLARUS Tactical Flashlight. Compact design; superb functionality; industry leading patented features
• Newest CREE XHP35 HI D4 LED, 2000 Lumen Max Turbo output,; beam reaches over 402 meters; industry leading performance
• Compatible with CR123A and protected 18650 Li-ion batteries, one 3600 mAh high-quality 18650 battery included
• Patented Triple-Switch control design, Easy to use; accommodates any user patterns
• Easy Interface: One-Touch Strobe; One-Touch Turbo; One-Touch Low; Mode memory; SOS;
Lock-out function; Capacity indicator, USB charging; ITS temperature control; Quick mode change
• Compact and light (Bezel 34.9mm(1.37") (D), Body 25.4mm(1")(D), Length 142.6mm(5.59")), Weight 130g, (4.58oz) w/o battery
• Patented Dual Tactical Tail Switch Control; One-hand tactile control; the next evolution in flashlight control UI
• Three Interfaces: Tactical Setting; Outdoor Setting; Advanced Tactical Setting
◇Tactical Setting: Classic KLARUS XT series control. One-Touch Turbo; One-Touch Strobe; Side switch full control; versatile in all tasks
◇Outdoor Setting: Specially designed for the wilderness. One-Touch Low; One-Touch Turbo;
Multiple levels with memory; SOS function; suitable for all needs in Hiking, Camping or Search and Rescue
◇Advanced Tactical Setting: Turbo + Strobe; Side switch disabled. Immediate access to Turbo or Strobe for extreme tactical needs.
• Common Micro USB recharging port protects again moisture, dust, and sand
• 1A recharging current; quickly back in action
• Intelligent Digital Charging module; monitors charging progress for safe and fast recharging with over-charging protection
• ITS temperature control, real time monitor and auto-adjust output levels to keep LED and crucial component safe for the best balance of performance and equipment safety
• Special Lock-out mode. Prevents accidental activation to prolong battery use and avoids damages to eyes
• Capacity Indicator alerts on remaining battery capacity any time
• Springs at bezel and tail resist shock and drop damages
• Reverse Polarity Protection; eliminates damage from incorrect battery install
• Aero-space Aluminum alloy body with CNC technology; Military spec hard anodizing (HA III); lightweight and robust
• Stainless bezel ring offers protection for crucial components
• Monolith bezel design for efficient heat dissipation
• Hardened Mineral Glass lens with AR coating; scratch resistant
Specifications
• Utilizes CREE XPH35 HI D4 LED with a lifespan of up to 50,000 hours
• Classic Tactical Setting as factory default
Notice: Only when using KLARUS 18GT-36 3600mAh battery or the same batteries of the other brand, the Max output could be up to 2000LM; When using the normal 18650 battery with PCB protection or 2 x CR123A batteries, the Max output could be only up to 1300LM
• Working voltage: 2.5V-8.4V
• Compatible Batteries: 1x 18650 battery with PCB protection or 2 x CR123A batteries
• Charging time: Depends on the battery capacity
Formula: charging time= (capacity of battery/1000mA+1H)
• Body colour: Black
• Reflector: Smooth reflector
• Switch type: Dual Tactical Tail Switch and Side Switch
• Dimension: (Head)34.9mm(1.37")×(Body)25.4mm(1")×(Length)142.6mm(5.59")
• Net weight: 130 g(4.58oz) (Excluding battery)
• Material: Aircraft-grade aluminum 6061-T6, Type III hard-anodized
• Waterproof: IPX-8 (underwater 2 metres)
• Lens: Toughened ultra-clear glass with anti-corrosion AR coating
enter the List if you want one for a nice price (to be negotiated...)
- Liber8
- archimedes
- Eivwer
- Wrathbringer27
- ReacherShoots
- will34
- xed888
- ilovejesuschrist
- fed893
- alejandrov
- allcool
- tzmxxhh
- syracuse
- akhyar
- Norddeutscher
- Corzy
- saypat
- olivedrab
- KCmastertech
- Mstevens113
- Charga
- ID4
- Gerrh
- khas
- dekozn
- Nicolicous
- charles lin
- casi29061965
- yellowknifenut
- uqs1000
- texas shooter
- D10ten
- ikaruz_500
- ikaruz_500
- vyvyra
- LG
- Yasin1981
- bluelion95
- Bruno28
- Anthon
- Nostromo
- indenial
- wurczack
- Aladin
- BazzH
- aL1
- alfas
- Aussi
- RobertB
- KawiBoy1428
- alexfra
- Lars (m@il)
- dariot
- Tete
- Gammel
- haro
- Mr.Beam
- e0mc2
- malamask
- allcool
- ollywood
- ale9g
- djburkes
- AirBreaker
- winz
- winz
- Maiden666
- Lars W. FB
- hanyon
- Zambo84
- AdAm0
- terjee
- goldtyson
- freddyt
- eifelmar
- odyssey
- eric800
- papaslightsaber
- stanley-beamish
- rastaman
- gorky
- kokete
- Paule
- rastaman
- Angel Martínez
- Cano
- Box
- XJojoX
- luisgcan
