The regular TM16 throws more than the TK75 2015. TM16GT should throw quite a bit more than both. What cells are you using?
Thanks for your replies guys! So maybe a cut dedomed K60 can probably match or outperform this light?
Does dedoming an xhp70 actually improve throw? I didn’t think there was much improvement to be had by dedoming the xhp series LEDs.
Vinh54 did that and looking at the pics it does seem to reduce the hotspot a bit
Mine got delivered today! I’m charging up my keeppower 3400 cells now and I’m really looking forward to darkness. This light is bigger than I thought it would be. The led’s seem pretty well centered and the fit and finish are good. It seems as though it’s time to step up to a 4 bay charger.
which lights do you have to compare ?
did i say PICS PLEASE! ??
how long is this buy gonna be? if it last till next week im in.
is it possible to get a code & the link?
Are flat top batteries just not tall enough or is there another reason not to use them in this light?
nitecore uses a plastic "foil" as reverse polarity protection
you need to have a raised top to get thru the foils opening to touch the contact
maybe my review of the TM16 makes it clear(er): https://budgetlightforum.com/t/-/34619
I don’t have too much to compare it to. I’ve got a nitecore MH20 and an OLIGHT M22 Warrior. I’ll take some pictures of it tonight. I don’t have a dslr to take accurate beamshots but I’ll try. And I need to learn how to post pics here.
I see now… Thanks Martin
If anyone would be kind enough to let me know if when you click on those links, does it take you to just a viewing page or do you have access to my account also from those links?
Thanks!
Here fixed for you… nice pictures! Would like to see a beamshot comparing TM16GT and BLF-348 at 300m range :bigsmile:
To make the pictures show in the post you must use the direct .jpg link (not the address on your browser) and paste in the insert image pop-up.
Here is one last one, just to make sure I got the hang of posting pictures. I didn't see the go advanced option for replies and this made the difference. Thanks for the help from all of you
Just got mine!!! That was quick shipping!!! Looks amazing, charging batteries now!
Yours came in a white box? Mine came in a brown box with a yellow nitecore sticker on the top.
Mine was in a brown cardboard box too with the yellow sticker on it. It just looks white in that picture.
Interested in one if still available
I would definitely be interested if under $100USD
