there is a latest news for the X3, the supplier told us there are some changes on it:
1. logo XINTD X3 change into Convoy X3
2. Driver changed for the LD-25, so it can be used in Flat battery and Pointed Battery
3. the battery holder is thicken than the previous
Not sure why the thicker sleeve was required, mine (the XinTD version) is almost airtight. Looks like a different shape, not sure if it would truly be thicker though.
The 3 AA carrier on the other hand has a tad of play if you shake the torch.
Did they “fix” the depression in the center of the emitter shelf?
Edit:
Well I think I will order one anyways. Drill a hole in the emitter shelf and press fit a 1/2” solid copper rod just like M4D M4X did… use led4power ld-1 and a dedomed U3 noctigon. I don’t have AA thrower so…
I reversed/flipped the plastic washer next to the rubber tail cap. The washer has a raised area on one side, so it gave a little distance between the tail cap and the switch. I think the switch is not as sensitive after that.
Actually I got this also this morning but was just curious if there was an additional change of length to the light to fit protected 26650s. I guess we’ll find out when it arrives.
