C:\avrdude -p t85 -c usbasp -u -Uflash:w:d4s.hex:a -Ulfuse:w:0x75:m -Uhfuse:w:0xFF:m
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.04s
avrdude: Device signature = 0x1e930b
avrdude: NOTE: “flash” memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file “d4s.hex”
avrdude: input file d4s.hex auto detected as Intel Hex
avrdude: writing flash (7372 bytes):
Writing | ################################################## | 100% 6.48s
avrdude: 7372 bytes of flash written
avrdude: verifying flash memory against d4s.hex:
avrdude: load data flash data from input file d4s.hex:
avrdude: input file d4s.hex contains 7372 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 5.07s
avrdude: verifying …
avrdude: 7372 bytes of flash verified
avrdude: reading input file “0x75”
avrdude: writing lfuse (1 bytes):
Writing | ################################################## | 100% 0.02s
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0x75:
avrdude: load data lfuse data from input file 0x75:
avrdude: input file 0x75 contains 1 bytes
avrdude: reading on-chip lfuse data:
Reading | ################################################## | 100% 0.01s
avrdude: 1 bytes of lfuse verified
avrdude: reading input file “0xFF”
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xFF:
avrdude: load data hfuse data from input file 0xFF:
avrdude: input file 0xFF contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: verification error, first mismatch at byte 0x0000
0xdf != 0xff
avrdude: verification error; content mismatch
avrdude done. Thank you.
C:\avrdude -p t85 -c usbasp -n
avrdude: error: programm enable: target doesn’t answer. 1
avrdude: initialization failed, rc=–1
Double check connections and try again, or use -F to override
this check.
