Im currently flashing my fw3a firmware, I’m trying to understand the hex code for the low and high fuse output, this is what im seeing, how do I translate it to the command to write the firmware?
avrdude: Device signature = 0×1e930b
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: reading input file “anduril.2018-08-22.EMISAR_D4S.hex”
avrdude: input file anduril.2018-08-22.EMISAR_D4S.hex auto detected as Intel Hex
avrdude: writing flash (8026 bytes):
Whats everyone using to view the hex files as code? I did a dump of the chip but not sure whats a good tool to convert it to human readble format (if thats even possible)
Why is that a bummer? The code on the flashlight is open source and available online… You’re trying to reverse engineer something that doesn’t need reversed.
I’m not sure, but I think avrdude might actually have a bug where it puts the labels in the wrong order in the “safemode” message. It looks like it swapped high and extended, and I’ve seen that happen a bunch of times before.
Double, triple check your pinout is correct both on the soic and usbasp. Also, make sure your chip
Is a t13. Most likely you know the chip, confirm your pins are correct.
