After reading BlueSwordM’s post, I looked at the spec sheet for the TLR-8A. That product has the 500 lumen light and a laser. The TLR-7A has the light only. The claimed runtime for the light is 1.5 hours. The claimed runtime for the laser is 60 hours. I terminated my laser test since I’m not willing to wait that long to test it. Here are the results I got from my LiFePO4 rechargeable’s.
TLR-8A light only, SureFire RCR123 LiFePO4 450 mAH rating, runtime = 17 minutes
Light started flickering at the end.
If a non rechargeable CR123A really has 1400 mAH, then I would guess it should run at least an hour but I haven’t tested that.
The 17 minutes was a disappointment. I may have to do any gun light training with a non rechargeable CR123A although I doubt I’ll be doing a whole lot of it.
My lasers like rechargeable’s much better.
Green bore sight laser, Soshine RCR2 300 mAH rating, runtime = 01:03:00 or 63 minutes
I’m happy with that. That would give me plenty of time to calibrate the target laser on the TLR-8A.
TLR-8A laser only, different SureFire RCR123 LiFePO4 450 mAH rating, runtime = 04:00:00+ or 240 minutes+
Terminated test because I was tired of waiting.
I’m very happy with that. That’s plenty of time to do more target practice than I can afford.
I have a TLR-8A and use a normal 16340 in it, an Orbtronic protected cell, though. It seems to work fine even charged up to 4.2v. I don’t think the drivers in these lights are so sensitive to self destruct when using anything other than what the lawyers from the light manufacturer say to use.
That IS interesting. Streamlight tech support absolutely refused to endorse or condone using anything but primaries in there. What kind of run time do you get with light plus laser?
Is there a way to put a “like” or “thumbs up” on posts here in case you don’t need a full reply?
I tried using 16340 in my TRL-8AG… output was a tad higher but it got hot much much quicker.
Didn’t want risk burning the tiny driver board so I stuck with primaries. For the amount that I use it for it’s cheaper to go thru CR123 than investing in several rechargeables.
On one of my Streamlight flashlights this is on the package
For 4x 123s vs 2x 18650. but they don’t list the capicity of their 18650s.
I got 1:22 on high with 2x Sammy 30Qs before dropping off the regulated output.
They list 2:30 at 1000L on 123s vs 3h on 18650s
All the Best,
Jeff
I haven’t done much real testing for run time so I can’t say. I also don’t use the light for very long amounts of time except for the laser which I sometimes keep on for a while to play with when shooting. I didn’t notice anything strange while doing that. See the other comment someone else posted about the light getting hot, I think these lights have the typical drivers which burn off excess voltage as heat. It’s a weapon light though, you shouldn’t be leaving it on for more than a few seconds at a time so the heat problem shouldn’t really be an issue.
