Hi All. My name is Ron. Just recently discovered this forum and joined. Please be gentle if I make any errors. This gets a bit long but please bear with me. I try to share any useful info I’ve found that might be helpful to others.
I did read the sticky in this forum category of CR123A rechargeable replacements.
I have an issue I’ve been researching for a week via Google, DuckDuck Go, Brave Search. I’ve been reading many dozens of articles and watching dozens of videos. I’ve read threads on forums such as this and others. I have not found a solution.
I have the following weapon lights which use CR123A primary batteries:
https://www.opticsplanet.com/v/69424-streamlight-tlr-7a-flex-tactical.html
https://www.opticsplanet.com/v/69414-streamlight-tlr-8a-flex-tactical.html
I also have the following laser which uses a CR2 battery:
StrongTools Red or Green BoreSighter
https://www.amazon.com/gp/product/B07DZ5BYFG/
I wish to be able to use these devices for training purposes with rechargeable LiFePO4 batteries. For non training use, I may revert back to the primary batteries. I know primary’s can be had for $ 1-2 each, but bear with me. Streamlight docs and tech support don’t recommend rechargeable’s and are no help.
I know that LiFePO4’s come off the charger at around 3.7 V. I also know that they stabilize to around 3.34 V. From research, I’ve determined that CR123A primary batteries come out of the box with a voltage of 3.0 V - 3.3 V (according to a Duracell spec sheet). I’ve read anecdotal evidence of the voltage sometimes being higher. I measured some of my own primary batteries and got 3.25 V for a CR123A and 3.29 V for a CR2.
Since these primary batteries may routinely be 3.3 V out of the box, I have to assume that the lights and lasers will handle 3.3 V without a problem.
So, my intention is to either discharge a fully charged LiFePO4 battery to EXACTLY 3.25 V - 3.30 V, with 10 mV accuracy; or to charge a discharged LiFePO4 battery to this voltage. The battery must not creep above 3.30 V, not even to 3.31 V. Under those conditions, I should be completely safe putting the rechargeable battery in the light or laser. There should still be some usable energy in the battery before it gets down to around 2.5 V - 2.8 V, etc.
I have this electronic load:
East Tester ET5410 Single-Channel Programmable Electronic Load 400W
I jerry-rigged a way to attach clip leads to the battery using a paper clip and rubber bands.
I have the following battery holders on order to make this easier.
Battery Enclosures SMT BATTERY HOLDER CR123A
https://www.mouser.com/ProductDetail/534-1050
Battery Enclosures SMT BATTERY HOLDER CR2
https://www.mouser.com/ProductDetail/534-1010
I am using this RCR2 battery:
CR2 Rechargeable Battery and Charger 15270 3.0V Battery
https://www.amazon.com/gp/product/B09FGPTT37/
and this RCR123A battery:
SureFire SFLP123 3V Lithium 1550mAh 2 Pack Battery (note the capacity is wrong there)
https://www.amazon.com/gp/product/B08MZCQ6T3/
(Interesting that the descriptions say 3 V, when in fact, these might damage equipment that runs on 3 V primary’s.)
I’ve currently been testing the CR2, which has a 300 mAH capacity.
So, my first thought was to set the load bank to drain at 100 mA down to 3.25 V. That failed. I’m assuming there was too much voltage drop initially and the load bank turned off. I am able to set the low voltage cutoff to 3.00 V and the load bank runs, but I have to manually monitor the actual voltage and stop the process. Also, once I do stop it, the voltage starts creeping back up on the battery.
That’s as far as I’ve practically gotten. I did confirm that I would have some usable energy left in the battery after treating it thus, although not obviously all of the energy. I have considered a crowbar circuit across the battery with a zener diode and a current limiting resistor and maybe a LED indicator light, but zener diodes are not generally very precise. I have also considered a precision charging circuit to go up to 3.30 V. But, I haven’t gotten any further.
So, if anyone knows how I could either discharge the LiFePO4 to exactly 3.25 V - 3.30 V (even at rest) or how I could charge the battery to exactly 3.30 V with 10 mV accuracy, I’d very much appreciate learning it. I want to be able to just charge then drain the battery or just partially charge the battery then pop it into the light or laser without blowing anything up.
Thanks in advance for any and all help. I have a feeling that, if we find a solution, there would be people other than myself interested in it. If you build it and get rich, send me a share.
Ron
