GXB100 - Gallium Nitride FET Single Cell 100W Boost Driver
Hello BLF,
Here's another driver I built for fun. I don't think anyone has built one quite like this before, so I thought I'll share it. This project is a little less polished than some of my other projects since I haven't really had much time to work on it, but here it goes!
Introducing the GXB100.
Note: This project is honestly pretty impractical; it's a mostly for-fun thing, so please don't take it too seriously. It works as designed, though.
What is the GXB100?
The GXB100 is an experimental single-cell synchronous-boost LED driver using Gallium Nitride MOSFET technology and capable of 100W.
It uses a slightly different but similar architecture compared to my previous flashlight drivers such as my GXB172. It significantly increases power handling capability (by twice!) of the GXB172, and improves on it with the addition of an improved fuzzy-logic thermal regulation, and audio-sensing capabilities.
For this experimental project, I've chosen the SP33 V2 as a developmental platform. Here are some of the features of the GXB100:
  • 100W power handling capability
  • Single-cell boost operation with extremely hi-drain cell (more on this later)
  • Gallium Nitride FET Synchronous Boost Topology
  • True constant-current regulation on all modes, 10 bit precision
  • Ultra-low no-PWM firefly mode
  • E-Switch Support
  • Fuzzy Logic temperature control
  • Triple channel auxiliary LED support
  • On-board Microphone for sound-activated control, or music response
The candidate host is the SP33 V2, due to it's fairly large size, decent construction, E-Switch support, and low cost. Images above from Sofirn's Aliexpress website.
The target LED is a single P2 XHP70.2 LED driven at 13A (~91W+ output), at 8160 lumens (from charts produced by Texas Ace from BLF and Kof3 from TLF), I don't have an integrating sphere unfortunately). LED images from Cree's website and Kof3 on the TLF forums.
Battery used is not a 26650, but instead a 21700 Samsung 30T, one of the best cells on the market of any size at high current load. I considered using a A123 lithium phosphate cell but the lower V_batt meant higher currents required at 100W. There's more than enough space in tube to fit the slightly longer cell. Meanwhile, I'm looking forward to 26650 batteries improving, which would fit the SP33 better. If you know of a better cell, do let me know!
Design
Using the SP33 allows for some nice features to this system. The top of the post is how the board looks like populated.
At 100W, heat is a big issue. Aside from obviously the LED, the large inductor is expected to get quite warm. The interesting thing about the SP33 is that it uses two PCBs, one for the E-switch, so I decided to use this to my advantage.
The two boards are designed in such a way that the back of the switch PCB has an exposed copper pour, and will act as a heat-sink for the large inductor. With the inductor connected to the PCB via large pads and thick copper contacts, the inductor itself should act also as a thermal sink for the rest of the driver PCB (albeit not a terribly great one, but should help nonetheless). The chosen inductor has an I_sat over 35A, one of my favourite inductors for its size.
Using Gallium Nitride FETs is overkill, but fun. Perhaps the first driver in the world using GaN FETs?
There are some benefits though, since these FETs have very low R_ds, very low gate charge, and essentially zero Q_rr. Total switching losses for the synchronous and main switch add up to just under 1.7W at expected maximum operating power (100W), compared to 4.3W for a regular Silicon solution (with some of the best FETs I could find), or 9.2W for a non-synchronous topology.
Programming as usual is conducted via the 6-pin header on board via my pogoProg. http://www.loneoceans.com/labs/pogoprog/.
In order to handle such high currents, instead of bypassing the spring, the entire battery tube is bypassed. This is done by soldering a wide copper foil to the long oblong pad on the bottom of the board, which sits beside the battery, and goes all the way to the bottom terminal.
Like my GXF22 driver (https://budgetlightforum.com/t/-/57383), I've temporarily chosen the ATMega328p/pb for the target MCU. No main reason, only because it's the same IC used in Arduino all around the world and it's so easy to program with a lot of flash space. Could have gone for a Cortex M0 or M4, but not sure if it's really needed ...
I did not make an aux-LED board, but instead, the E-switch button on the SP33 is translucent. An RGB LED is placed under the switch so it lights up with RGB control. Can be set to whatever effect you'd like. Right now I use it to display battery voltage from Blue to Green to Red.
Finally, ultra-low/firefly/moon modes are typically not too great on switching drivers, since even 0.1% brightness of even 1000 lumens is 1 lumen - too bright for most! This board has integrated circuitry to enable very low firefly modes, if that's what you want. :)
More to come soon.
Have a good day everyone!
100 Watts, that’s just crazy awesome. For your next design you may have to design something for a multi-cell light, I think you’ve about reach the top of what a single cell can produce. Thanks for sharing this and all your design’s loneocean. I really enjoyed building the few I have done.
Really nice to see someone thinking outside the box, that’s usually what sparks change and improvements in everything.
Still hoping one day to see the GXB172 driver for sale online somewhere. :wink:
I’ve never heard of Gallium Nitride FET, so I looked it up quickly. I’m very impressed! This driver is definitely over-the-top! :partying_face:
Wow. GaN!
So, you need a 30T then? I guess Shockli 5500 mAh will do that current in bursts, and neither the cell nor the heatpath can handle it for continuous.
Am I correct in understanding you predict ~98% efficiency at 100W?
Try looking at the Convoy M3. It weighs 290 grams and allows the Shockli 26650 5500 mAh to fit along with 21700 cells. 21700 o-ring/spacers provided. Might just make that driver almost practical.
I don’t see a boost IC here…
Thank you everyone for your kind words! Scallywag, I haven't been able to measure actual total efficiency but it's >90% based on quick measurements. There's a fair bit more losses in the inductor, DCR losses in the board, contacts, wires, as well as gate drive. I'll have more details as I get around to them.
Agro, there is a boost regulator IC on the main board. It's partially blocked in the image above by the switch-pcb.
Texas shooter, that looks like another excellent host, thanks for the recommendation. I think it probably wasn't around when I made this driver at the start of this year. I'll do a little more reading about it.
Here's the best Lion 26650 for high current: It does ok at 25-30A but just barely. Also sold under Aspire brand.
https://lygte-info.dk/review/batteries2012/Golisi%20IMR26650%204300mAh%20(Gold)%20UK.html
Still no 30T but at lower voltages it may not be so bad.
loneoceans I have no words to explain how amazing this is. wow.
Thank you very much for pushing flashlight driver development boundary. You make the most original and unusual driver designs today i have ever seen.
This driver made me dream about roughly-E07-sized quad XHP35 HI light. Quite throwy, efficient at moderate currents (and therefore offering high sustained performance) and still capable of 8000 lm OTF.
Thanks everyone again for your kind words! @Texas Shooter, thanks for letting me know about the new Convoy M3. I also found out about the new S21A, which would make a perfect host for an optimized GXB202, with an XHP70 LED...
Thanks for that link! You're right that it's very good, but the 30T is still the top at 30A+ drain. If anyone can suggest a better cell, I'll be interested. For now, I've been testing with the 30T and it's a very nice cell though, 100W with not too much sweat (alright, some sweat, but hasn't blown up yet!)
At first I thought this would be great, 100 watt drive. So the 40-75 watt range should be a good efficient sweet spot, 5000-6000 lumen XHP-70.2. Then Argo had to say quad XHP-35, and I got giddy. Both on a single cell 21700 to 26650 host and the pocket rocket war begins again! I don’t really envision the full 100 watt use except for very limited turbo. But even under the max it’s going to be a beast!
The new S21A weighs 75 grams. https://www.aliexpress.com/item/33011209997.html?spm=a2g0o.detail.1000013.9.7dff411eYYhCcj&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.128609.0&scm_id=1007.13339.128609.0&scm-url=1007.13339.128609.0&pvid=7253beab-1518-4438-aa4b-23f179a66ded
The also new S11 weighs 160 grams. https://www.aliexpress.com/item/32973533445.html?storeId=330416&spm=2114.12010612.8148356.1.75a45d5asXqUfT
The L21A weighs 540 grams, best bet for longer max runs. https://www.aliexpress.com/item/33024748265.html?storeId=330416&spm=2114.12010612.8148356.5.75a45d5ahhwbSI
All have mechanical tail switches that would need to be replaced.
The M3 weighs 291 grams and has an electronic switch. https://www.aliexpress.com/item/33013718846.html?storeId=330416&spm=2114.12010612.8148356.3.43456d6cIZ4g4N
All are excellent quality and should make great lights.
Thanks for the feedback! Right now I'm a little tied down with things to be able to get a quad XHP35 system, so the target is still a single XHP70.2 LED. More to come soon.
Getian GT-FC40 would be a great LED to use with this driver. :slight_smile:
Oh yes...^^^^
I am super impressed, I could think of all sorts of uses for a driver like this. Like a LOT of uses lol.
Good work like usual!
Itching to know what GaN IC you used for this little beast!
Something like this would be great for a Mini-Giggles-Monster hosted in an L21A!
That’s what you did for fun!? I can’t wait to see what happens when you get serious. I would definitely buy a flashlight with your warp driver in it. :+1:
