Gyrfalcon S8000 Battery Charger and Analyzer Review
Thanks for the update. I assume it still does not have automatic battery -type recognition?
And from the sounds of it the sliders are still not that much easier to slide?
Sliding has not been a problem with mine… the negative contacts being so short makes getting cells in and out a PIA though.
Enova is working on a simple mode with automatic battery type recognition and USB-C input.
It’s easier to move the sliders by hand because the negative ends are longer.
The outer two sliders are smoother.
I haven’t really had an issue with the sliders. They’re not as smooth as Vapcell BL4 or XTAR VX4 but I am not trying to move super fast while charging cells and it’s less noticeable when working with 18350 or 18650 cells.
Thanks Tim. By ā€˜simple mode’ do you mean the S8000 will get this mode from a firmware update via USB-C? I thought the S8000 only has a micro-USB port?
The S8000 has three main modes at the moment. Two Normal and one Professional. The Simple mode might be a fourth option with automatic battery type detection.
Firmware can be updated via the micro USB port on the side.
The S8000 currently has a DC socket for input. This might be changed in the future to USB-C while the micro USB port on the side is used for data and firmware updates.
Thanks Tim. The extra mode to simple and auto battery recognition via micro-USB sounds great.
This being hardly ā€˜portable’, I don’t see much difference between a DC (5521 they said in another thread), or USB-C input, but I guess USB-C might make it easier to sell.
Whatever, I won’t be getting one until it has auto-battery recognition. Thanks again.
While I think of it, assuming Enova might read this thread, it would be good if they added 1.5V Li-ion charging to any updates that are in the works.
I don’t really care about the USB-C v DC5521 charging but if they are in to changing ports/inputs, why not also update the micro-USB to USB-C: that would be useful (and also make it more saleable).
But for me, If they add auto-battery recognition and 1.5V charging, I’ll get one for sure, since I will also be able to charge longer batteries.
That got added pretty early, more than a year ago.
Thanks - I musta missed that. Only auto-battery recognition to go then!
