I have a light with this software installed and love it. I want to purchase another one, but don’t want/need the FET turbo mode.
So, my question is can the FET be removed from the board without affecting the regulated levels?
I thought about just not using the turbo mode, but when cycling through power levels it can be easy to hit turbo accidentally. I use high drain cells like Molicel and A123, so turbo can cause a meltdown.
Yes, that is the driver I am looking at. You can program the levels to whatever you want, but you have to ramp up and down to do it. I may accidentally hit turbo when ramping up and poof the emitter. That is the reason I want to completely remove it.
I think you can remove it and it won’t cause any problems. Just out of curiosity what emitter combos are you worried about? And are you using LiFePO4 A123 cells?
