Hi friends
This is a-guai , a flashlight-enthusiast and Outdoor-travel enthusiast from china.
I received a MT01 sample sponsored by Haikelite company.
It’s my first time to post here, if i make any mistake, please be kind to correct me.
All my collections are AA , AAA size small light. Personally i dont like big flashlights very much.
MT01 is my first 3x18650 form flashlight, it’s smaller than i thought, very compact size. I like the design and shape.
2200 OTF lumens with 100 minutes constant brightness, this light is really a practical light for outdoor travels or working.
Share some beautiful photos first ;
Specifications from HaikeLite
www.haikelite.top
—Emitter: CREEXHP50 V2 CW / 5000K NW
—Aluminum Alloy body with HAIII Anodize black surface Finish
—Battery: 3x18650 / 18700 in parallel (works on all kinds of 18650 battery, flat-top or button top)
—Aluminum Reflector
— Ultra Clear Double-sided AR coated toughened Glass lens (99%light transmittance)
— IPX8 Waterproof underwater 2 meters
—Max Brightness: CW 2500 Lumens
—Shot distance: 300 meters
—Full Current Regulation; Boost driver ; Real driver efficiency > 93%
— Build-in Anti-reverse protection in flashlight driver. If you put the battery reversely, there is no drain coming through.
— Anti-discharge protection;
—Brightness Level:
Low Low 50lumens 75 hrs
Low 250 Lumens 15 hrs
Middle 850 Lumens 5 hrs
High 2500 Lumens 95 minutes
Strobe: 2500 Lumens
Size: 135mm length x 51mm Head x 45mm body
Weight:280 Gram
UI:
Click on — Click off
Hold switch to change mode
Dolbe click Hidden Stroble
With Last mode momery
Packing is made of some kind of PVC, a light but very solid nice box.
Now open it up. a flashlight ; O rings ; lanyard and a manual
HaikeLite in my hand; My hands are very small as a man , but still very handy to carry it. Anodizing surface finish feels good, not slippy at all in a sweating hand.
Since my hand is small, It’s hard to imagine the real size of MT01.
Now compared MT01 with other 18650 lights side by side.
From left to Right: Olight r50 ; JETBEAM T4pro ; MT01
some 16340 , AAA , AAA size from my collection
Size and Weight
From my measurement , the net weight is 320 gram ; Size: 140mm length ; 53mm head diameter ; 43mm body diameter. Considering the size and weight, it’s not an EDC light , however as i said , it’s a very practical light in work and daily life.
With batteries, it weighs 464 gram
Really like the black finish
Emitter, Lens and Reflector:
MT01 uses the newest CREE XHP50 v2 , i heard it has better light efficiency. The reflector is not SMO , but a Micro orange pill finish. Emitter is well centered, that is nice.
Anti reflector coating Lens also looks clean and nice.
Bezel is flat and made of stainless steel.
Aluminum Reflector size: 46mm diamter and 25mm height, 14.5 gram weight
2mm lens
Take the bezel apart
emitter inside:
There are 2 screws to fasten the DTP MCPCB. The wires seems like #20 or #22, i am not sure, Haikelite have not reply me. Intergrated emitter shelf is nice for heat-cooling.
The emitter
Cooling grease on pcb
Switch:
The switch is electic switch and solid rubber boot. Clicking and changing modes is smooth and convenient. But personally i like metal switch more. The black rubber switch gets ash and dirty easy, you have to clean it.
Cooling fins , 5 cooling fins are thick and deep. MT01 has very nice heat transmission, i can hold the light in a outdoor camping all the time on high mode.
Three logos
I think the “MT01” logo should have been engraved harder.
the landyard hole is big enough to attach the SS claw of the landyard, but i am afraid SS claw will wear out the anodizing surface.
The backcover can be taken off. But you can not put in the batteries from the back.
head and body apart; trapezoidal threads is nice and smooth. 3 threads is a bit less, maybe 4-5 threads is more stable, not sure, but each thread is strong enough.
All threads are anodised.
Disassemble the driver… nice looking driver
The body from upside. As you can see, the edge of the un-anodizing part is not identical. What? The upside edge is thicker and the downside edge is thinner. the factory should be aware of this.
1 or 2 or 3 pcs of battery can work well due to the boost driver
Beam Shot
My version is CREE XHP50 NW 5000K , The edge of beam has a little bit green. Beam is nice , no pwm, NW tint is kind of yellow.
50 lumens extreme low mode, 1.5 meters from wall
Outdoor 50meters distance
HaikeLite MT01 2200 Lumens
Olight R50 2500 Lumens
Jetbeam T4pro 2580 Lumens
Beam angle
Waterproof test IPX8 (underwater 2 meters, but i have no suitable tool to test it underwater 2 meters, i drop the light to a small fishbowl and let it last 10 minutes)
Turn the light on and off underwater from time to time
Soak the turned-on flashlight into the water for more than half an hour; It works all good, waterproof test passed.
Continue at post #2 and #3
Sorry for the rough and simple review and bad chi-english.
Thanks for reading.
a-guai
