Interested depending on price and if it can take protected cells. I know that they might not preform quite as well as unprotected but I like the less chance of exploding.
Why would a quad have a larger hotspot than a triple if the reflector diameters are the same? The hotspot size would stay the same and the intensity would increase 33%.
Here are some quick calculations I did with my own MT07S. Mine happens to be a NW version so it is a tiny bit lower than a CW would be but still Close.
70,000 Candela and Calculated throw is 529 meters.
That is with the 70.2 emitter
I have a couple of lights that use the 35 high but the best from the short testing I did tonight gave me the the following results.
Using a 26650 purple efest the candela is 72500 and a calculated throw of 538 meters all from a single tiny little 35 high emitter.
I love the raw power of the 70.2 and it will without a doubt kick out an enormous amount of light. But if you are looking for distance only. The 35 high version might be the way to go.
I have not tested either version of the new Haikelite yet. I just thought it would be fun to show the differences in throwing distance of the 35 high verses the 70.2.
Both are going to be great lights and I am well past ready to actually do some testing.
This is probably going to be one of the times I am going to end up with both lol. One for just the raw power and the other for the hard to believe throwing power of the 35 high...
I am pretty sure most here know how to calculate all of this but, for any of you that may not understand how to calculate this for any of your own lights shoot me a message and I will type out a very simple way to do this yourself.
Hi Terry, that is why i told Haikelite since they say not completely good at measurement of candela, to do things below if they may:
1.go to open space outdoor
2.Measure the max lux reading of a good MT07S XHP70.2 CW at 5 meter, let’s say reading A
3.Measure the max lux reading of MT09R XHP35 HI at 5 meter, let’s say reading B
4.Do a simple B/A
If B/A is very close to or over 4, then it is indeed around or over 300kcd.
Haikelite did mentioned they compared max lux reading of MT07 SMO CW and got triple ratio, so since MT07 SMO CW is above 100kcd, so this MT09R XHP35 HI should be above 300kcd. That is right calculation, but environment and distance can affect measurement.
I actually calculated the throw of my Q8 tonight as well... Now this will be different for almost everyone as many have modded their Q8 to suit them..
I have as well but I am comfortable with the current light output from my Q8 so I stopped at some of the more basic mods.
Anyway my own Q8 came to 60,000 candela with a calculated throw of 490 meters. And please keep in mind that the total output of my Q8 in lumen is much higher than for example the MT07S, almost 7k lumen in fact and still didn't catch it in throw.
As far as I know I have a sample on the way or should be soon... I actually did request the 70.2 version so I not sure how much help I am going to be.
I wished I had the chance to test one of each if for nothing else just to calculate the candela and distance of each light.
The math seems hard when reading all of the different definitions of Lux, Foot Candle,
Candela, Lumen.
Truth is that that all interchange with one another and it becomes much more simple.
I can sit with someone and just write it down on paper and they totally understand it. That same person reads a book or goes to a website and tries to understand all of it from reading all the information is really not much better.
Lots of really killer mathematicians love to make what is very simple seem impossible for most to even begin to understand as they will write it out in an equation that looks very scary lol...
The simplest method is forget all of the squared this and squared that and just do the basic math. The hardest part is the square root.
As you said take a lux reading at a measured distance.. I normally like 5 meters. I have used 10 meters but very seldom.
At 5 meters say you get a max lux reading of 500....
Take that 500 lux and multiply it by the distance twice.
500 x 5 meters = 2500 x 5 (I said twice) = 25000 This number is actually your candela but lets not worry about terms right now..
Now take that 25000 and multiply it times 4....
25000 x 4 = 100000 and then the square root of that 100000 which is 316. In this case you calculated distance would be 316 meters.
It really is that simple.
I hope this helps a bit...
Either way when a sample arrives I will calculate any number you want lol... I will probably have most of that completed in the first hour.
^ That’s where the expression “don’t be square” comes from? Meaning yo bro just show me them beam shots!
Hold on. That’s post #90 probably. The word triple is used to describe their MT09R as a triple emitter light. Haikelite only says throw is much better than MT07 70.2.
^ But he’s requested the 70.2 version, and not the 35 HI version…
I think both versions should be tested for proper A/B comparison, just like with the Imalent DN35/70 you did some time ago Terry. Only then you can truly understand what these two beasts are about. :sunglasses:
Beam intensity ~= surface brightness * reflector area
Total reflector area is close in triples and quads.
I said with quads it’s a bit higher, but I missed the cutouts where LEDs sit. It may be the other way around. Hard to tell by the eye. Anyway, it’s close.
Same surface brightness, same area -> same beam intensity.
But you get the same intensity with more lumens and these lumens must go somewhere. They make the beam larger.
Saying the same differently, with each individual reflector, quad will have the reflector smaller. Smaller reflector = wider beam.
Exactly... I can only request one of each. But the decision to send me one of each is totally up to Haikelite.
If by some chance I do get 1 of each I can promise you the math will be as good as I can calculate it. And you know I gotta go find a spot to shoot some side by side beam shots both still and video.
They are both going to sell and sell very well I do believe. Some like the added throw some like the mix of both and some like most of us like both.
LOL sorry Dale... I promise I did not intend to put you in this position.
That side by side video blasted in views in jist a couple of days so people definitely want to see the difference in one place at the same time...
Either way you guys will get honest numbers and real normal everyday use beam shots.
If they do decide to send one of each I need to find at least a good 600 to 700 meter area to showcase each.
