Please put a generous radius on those pins. I wouldn’t go for a full radius though because that would allow the tip of the fat pin to fit partially into the small hole.
I still don’t think turbo is in the normal sequence. Description says low, medium, high.
Turbo is double click. The ui would be so much better if turbo is in the sequence and so that it can be a mode that can be memorized.
I agree - turbo in the sequence is better. In Narsil, I have quick access from OFF to last mode, moon mode, and max/turbo (click, click&hold, double-click) -- what could be easier on a single e-switch? Everyone gets what they want. I normally prefer no mode memory with e-switch's, but when you have easy access to all 3 possibilities, why not?
A bunch of stock lights now have 2 of the 3 features - not sure if any do all 3.
couldn’t have said it any better.
thats what i was trying to tell their company….be unique and stand out from all the rest, put turbo in the sequence so that it can be memorized.
the ui they have now, is similiar to olight, nitecore, thrunite, sunwayman, etc…
this way the user has many options….
BLF user everydaysurvivalgear can explain thing very nice in his YouTube videos
Mhanlen makes good videos
Old Lumens has about the perfect voice to bring all pros and cons to light.
And these are just 3, your inbox is about to explode
XHP35 HI throws better for sure. But the output can not go over 3000lumens.
XHP70 can output more lumens, the deep and thick cooling fins of this monster are designed for XHP70. Heat-sinking is amazing, on 7.5A turbo mode the big head part gets warm quick and never get too hot.I can hold the light in hand all the time.
Smooth reflector does make the light brighter than OP reflector. I will update some beamshots next week to compare the difference between SMO and OP side by side.
