Hello, I’m trying to make a headlight for my dirt bike. I have an 20 Volt (18 V ??) Dewalt drill battery to power it. It is the smallest 20 Volt model. It has a capacity of 1.5 amp hours. They make an adapter mount that I could Mod to hold the battery and have it snap in place. I could get DC output from this.
I’d like an LED light that I could mount to the front of the bike that would give me a decent spread of light. If it had a flash function that would be a bonus. The amount of choice is dizzying and I don’t have a clue what might work with this voltage or be of decent quality (Take vibration). Looking for something that would light up about 100 yards or so, with the sides being lit up too (Not a spot light).
I would look at some of the mountain bike lights. You may need to do a driver swap to use the 20v pack though, most of them are running 7.4v packs (2s2p).
KD uses NCR18650GA cells to make those bat-packs - can’t go much higher quailty
I have one of those Solarstorm cases for 4 Cells - mine has a pretty high self-discharge and emptied my cells in a week down to 2V.
But it works and it is waterproof - you just have to know about the self-discharge. (also mentioned here: Review: New "Solarstorm" 2S2P 8.4V "water resistant" 4 x 18650 battery case for bicycle lights under “Standby current”)
so just detach the top from the pack if you don’t use it.
That would be quite expensive and add more weight I would think. I think the bike light makes the most sense though, as these usually have a flasher function. Thanks for the suggestions.
