I received the Olight S20R from Banggood for the purpose of review.
I've gotten to where I would rather do a video of it, than photos, but here are a couple photos of the light.
Here is the link to Banggood. http://www.banggood.com/Olight-S20R-Baton-CREE-XM-L2-4Modes-Rechargeable-EDC-LED-Flashlight-p-948418.html
I'm having issues with both IE 11 and Opera, so links don't do what they should. Neither browser works right any more with the forum posting.
Specification:
| Product name: | Olight S20R Baton CREE XM-L2 EDC LED Flashlight |
| Brand: | Olight |
| Model: | S20R |
| Emitter Brand | CREE |
| Emitter Type: | XM-L2 |
| Light color: | Cool white |
| Material: | Aviation grade aluminum body |
| Mode: | high,middle,low,moon |
| Battery Configurations: | 1 x 2600mah 18650 battery(included) |
| Switch Type: | clicky |
| Switch Location: | body side of the flashlight |
| Impact Resistant | 1.5meters |
| Brightness: | 550lm,120lm,5lm 1LM |
| Range: | 118 meters(max) |
| Runtime: | 2h(high),9h(mid),120h(low),480h(moon) |
| Lens: | anti-reflective coating lens |
| Reflector: | Special designed smooth reflector |
| Carrying clip: | included |
| Waterproof: | IPX-8 waterproof |
| Color: | black |
| Weight: | 52g without battery |
| Size: | 108.5 x 23mm(length x body diameter) |
Features:
1.Stainless steel head ring can bear higher impaction
2.high efficient drive circuit, compatible with any rechargeable and non-rechargeable 18650 battery
3.Automatic memory function can memorize the brightness level while off.
4.There is a lanyard hole in the tail which can pass through fabric strap with diameter of 2mm.
5.Battery reverse polarity function guards against improper battery installation
6.Comes with 1 x 2600mah 3.7v rechargeable battery and a charger base for convenience use.
7.With strong magnet in the end of tail, the flashlight can be stick on the iron surface. The magnet can be removed and replaced by users.
18650 battery:
2600mah 3.7v rechargeable lithium battery
More than 1000 charge-discharge cycles high quality lithium battery
With protection board function for protect the battery from overcharged and discharged.
Package included:
1 x Olight S20R Baton CREE XM-L2 EDC LED Flashlight
1 x 2600mah 18650 rechargeable battery
1 x Charger base
1 x USB cable
It is a very nice light, but BG needs to do a "special price" on it. It is not worth the asking price of $69.95
Sorry, I have to call it as I see it. Nice light, and even better at $49.95 or at least lower than the standard price, but the price is high because it has it's own specialized USB charger and comes with an Olight battery too. I know they put a lot into it, but I just cannot justify the cost, for what you get. Enthusiasts like us would drop the charger and battery and charge in our own chargers. I hope they can come down on the price for BLF members.
I get nothing out of this review, except that I get to give the light away to one of you members. Just FYI. Links are non-affiliated.
