i have a hd2010, forget where i bought it from
read other threads on here that most run an east 092 driver, and are pulling around 4 amps at the tailcap
my driver is a no-name and on high it is pulling around 0.7amp on a charged keeppower protected 18650
The lip in the aluminum where the driver sits measures 17.60mm
The driver dimensions measure 17.10mm O.D.
Driver fits slightly loose but is held down firm by a retaining ring.
What is a good driver swap to put some power into the xml cree so it can really shine
or can I mod the driver to make it output more power to the emitter.
yes i was using just a cheap multimeter at home where my good one is at work but on the same hand the driver has even thinner wires that go to the emitter than the wires on the multimeter, i have never seen such thin wires running to an emitter.
should i go with that driver, or is there an even better driver. i don’t get to spend as much time as i’d like shopping around, so i don’t know what all is out there on the market.
Their stock on those is mixed, they've been sending out 3 different versions all under the same SKU. Some are sub-1A, some around 2.4A, and a few are the original version that behave like a proper direct drive driver.
Dunno where you are, but mountain electronics (USA) sells a qlite driver you can have him modify to pretty much anything you want for around $5. That would be my choice in your situation. It will probably be a bit more for international.
