I got my first Rotary, after many years of saying they are too big, too heavy, and too expensive… that is all true, but, I just could not resist trying one out for myself.
I like that I cannot see the flicker on Low mode on HDS, which I can see on the Novatac. Both use pulses, but the HDS hides them better, in a way that most people wont notice.
I can only see the PWM on the HDS
if I wave the light, but that is not what I do with a light “in normal use”. (Im not normal).
Ive set up the Rotary and the Clicky with all the same levels. The only difference is that with the Rotary I can change levels without clicking secret codes.
Since my Novatac has my favorite LED, I find I prefer to use it over the Rotary… which means, the Rotary is going to need an LED swap ![]()
fwiw, the HDS is heavier, by 20 grams… slightly more than the weight of a spare 16340. These lights also work with CR123, but I dont use those cells, they small bad, and I cant recharge them…
One thing I do not like about the Rotary, is that if I turn the dial too fast, it feels like Im getting strobed, because the ramping occurs in steps, it is not continuously smooth…
Thats OK, the benefit is I can see when I turn the dial, slowly, that the brightness has changed by a visible increment.
Bottom line is the Rotary and the Clicky can both do all the same things… except the Rotary is Brighter… On my meter, which reads about 10% low, the Novatac maxes out at about 90 lumens, and the Rotary maxes out at double that…
The Novatac has an advantange in how it can be configured for Battery detection. It stays set to whatever battery I trained it to recognize. With the HDS battery detection is automatic, this presents a problem if I open the light to test the battery. It is possible for a low battery to fool the HDS into thinking it is a Primary, and this can overdischarge a LiIon… but I use protected cells, so I dont have to rely on the HDS/Novatac Low Voltage Warnings… which are useful, but not equal to full Protection.
Im very impressed with the HDS/Novatac narrow beam and tight hotspot… It throws really well, and is suprisingly bright, in the small area of the hotspot. Makes it easy to see the fence at the end of my back yard, or accross a street.
The programmability of these lights is really cool… and I like that they have sublumen lows, plus an option for a strobe, and the nifty ability to press for maximum, and double click back and forth between a low and a medium level.
Im using the turn on preset for my lowest mode, a double click for 20 lumens, and a triple click is reserved for strobe, which I find useful when crossing the street. I notice cars really take my pedestrian mode seriously when they see the flashing light. They come to a complete stop. The other day, during the day, I used the strobe to inform a car that wanted to turn across the crosswalk I was in. I got a smile from a pretty woman that was driving… I think she wanted to date me, cause I have such cool flashlights, but, I was not available to pick her up, so I let her continue on her way with just a friendly wave.
here are my dynamic duo:
Life is good in High CRI… even Cool White Low CRI is good in the dark, but, High CRI is just Better… for me ![]()
I love my Pink Nichias! on left 90 CRI N219b 4500k 9080, a grail LED for me. On right 73 CRI XPG 6200k
fun times ![]()
