Are there any decent headlamps using 18350 batteries? I think that Soffirn (I’m not sure if this is truly Soffirn’s) H25LR is just great, with its simple high CRI + 660 nm deep read (regulation aside), but is there something similar with the shorter batteries?
Here’s a list of lights that can be used as a headlamp and at least have an 18350 option
http://flashlights.parametrek.com/index.html?type=headlamp&battery=1x18350
Skilhunt H200 mini (the red is 620nm)
Nice, and probably nothing wrong with it, but I wish it had a regular USB-C charging and be a bit more budget friendly…
Would these two take 18350 batteries? I thought they were 16340.
My bad, they are. But here
Cheers! If it only had the red LED as well… I guess you can’t have everything.
I prefer to have a spare battery to swap in. I dont like to put a light out of commission, so it can act as a charger.
Skilhunt uses Regulated Drivers w NoPWM… most other lights use FET and PWM
the taste of quality lingers long after the price is forgotten
if you just want a cheap usb headlamp, the Sofirn HS10 can do that, but be sure to unscrew the tailcap when not in regular use, as the parasitic drain will kill the battery in 2 months (and its not 18350). Nor does it come w a Nichia 519a like the Skilhunt does…
It looks like there is slim picking in the 18350 headlamps department, especially with good primary and red emitters, like the simple @Sofirn H25LR. I wonder if there would be an interest should one be on offer?
Wurkkos HD15R is worth looking at.
Oh, and that could be shortened to 18350, I imagine?
It actually even comes with short tube!
Yep, standard Sofirn/Wurkkos threads.
I have the non-red emitter version. I don’t find flood/throw to be very useful to me so I probably should have gotten the red one. It’s easy enough to emitter swap.
But also this one… :-(
18350 tube for Convoy H1 ![]()
There is also Sofirn SP40 and SP40A both of which include short 18350 tube. Does anyone have any experience with them?
The SP40A with the 18350 tube would be such a sweet light if it had the FC11C new regulator (and maybe a little red LED somewhere ;-). It’s probably still sweet enough… Could anyone comment from experience: especially if you have the LH351D version - is it nice?
