That’s scary, but not likely to happen. IFF you use a clicky switch, your scenario will probably do no more than render your light into a single-mode High-only model. The Good News is, this will disable the stupid blinking!!! The bad news is, … well, I can’t think of any, but I confess I despise the blinking enough to insult the thought of it with my Username… Losing the dimming might not make most of us happy, but IMNERHO the torch will be dim enough soon enough, as the wee battery dwindles its short life away.
When I have had this happen (in two hosts so far) that’s all I get. E.g. on my last F20 XM-L upgrade, the reflector stuck to the O-ring as I was tightening the pill, which caused the LED PCB (thermal paste, not adhesive) to turn enough to push the (+) wire into the PCB & create a “short”. One-mode, full bright. YIPPEEEE!!! Until I dropped it (not on purpose!!) from ~7’, apparently released some tension in the head & the “normal” modes returned. Oh, well… On the P60 host where that “mode delete” happened, I repaired it, which is how I saw the “short”.
It gets better: If you’ll upgrade your emitter to an XM-L or SST-50, these will handle pretty-much all your battery can produce without failing. They will get plenty hot, plenty soon enough you’ll deal with the problem before you lose any body parts!! Still no biga-badda-boom.
IAC, the guy who sells me miles of data cable assures me that “Plenum Rated” wire of the appropriate gauge will have a high(er) temperature teflon coating. I asked him if I could buy a foot (cost=pennies) & he just cut as much off & handed it to me. If there’s a “cable and connectors” wholesale vendor near you (look for “bulk ethernet data cable”), that would be a good place to look.
One last thought: IFF you use wire where the insulation fits the hole very closely, the worst you’d get from any melting wouldn’t let the wires touch. The plastic would center the wire & prevent it moving, and should “puddle” in the hole when melted & not allow the wire to move much, assuming it’s screwed down inside the head. By the time your human hands could touch it again, the plastic would be set & you could handle it at your convenience.
You must be signaling space aliens with that kind of power!! 8)
