Edit:
I moved the thread from “Flashlight Modding and DIY Parts” to “want to buy”, as I’m in over my head if i have to make the flashlight myself.
Hi ![]()
I need some good advice before I buy, or make a uv lamp diy-style.
The lamp is for when I go treasure-hunting for amber at night by the sea.
During my research I’ve searched this and other forums, and found several informative/relevant threads:
http://www.alieneye.info/tubelight/index.html
But i still have a lot of questions
My requirements for the lamp:
- Powerfull UV light at 365nm or less - Amber is fluorescent in uv light at wavelengths from 320nm to 380nm (some says its only from 320-365nm)
- Must be able to illuminate a minimum af 5-10 meters.
- Battery life of at least 3 hours - maybe an external 12v battery?
- Filter for filtering out visible light. - like this http://www.viewpointlaboratories.com/trueblack/mr16-trueblack-365-nm-12-led-photo-quality-uv-blacklight-spotlight/
- Max price of aprox 250 usd (maybe a little more)
- Rainproof, not waterproof.
I have found these products, but most are quite expensive, or you have to order more than one. Therefore, I am examining whether I can make a similar or better lamp, at a lower price:
http://www.shop.gregmcgeeengineering.com/U301-365nm-Nichia-UV-LED-Flashlight-019.htm
http://www.dyron.fr/page_article.php?id_article=77&cat_article=eclairage&language=2 (wavelength?)
Hartenberger Taucherlampen und UW Handleuchten - wegweisend in der UW-Beleuchtungstechnik Expensive!!!
http://www.uvcuringlamp.net/uv-curing-lamp-365nm-10w-p-542.html (cannot order only one
http://taoyuan.en.made-in-china.com/product/vBxECHXlCUcD/China-UV-Curing-Floodlight-365nm-20W.html (Cannot order only one)
http://www.bergeng.com/TRI-365HA-prod.html
Questions:
I have searched the web for housing for MR16, but have not really been able to find any good ones. Maby “housing” is not the right search-term (I’m from denmark). Only a lot diy made out of water pipes and similar. Do any of you know any resellers of housing for the MR16 with GU5.3 base? -Or are there better options for diy than MR16 with GU5.3 base?
Housing and diy:
http://nordicgroup.us/s78/indexn.html#MR16%20Lamp%20Based%20Headlamps
couldent find a reseller of the dual setup in the above link ![]()
Additionally, I am in doubt about which bulbs/LED’s are the most powerful and which ones best suit my purposes -or if there are better alternatives I do not know about:
http://dk.mouser.com/search/refine.aspx?Ntk=P_MarCom&Ntt=161382735
http://www.goldengadgets.com/365nm-uv-ultraviolet-3-watt-led-light-bulb-mr16-12v-dc.html
Furthermore I would like to test the difference in light emitted from amber under a wavelength of 365nm, and in a lower wavelength. If someone has two different UV lights, preferable a 365nm, and one between 320nm and 365nm, I could send you some pieces of amber, so we can test the difference.
I have a pair Oakley M-frame sunglasses. Does anyone know what lenses I should buy that protects best against UV rays, and possibly highlights the reflected light from the amber? Preferably not too dark lenses as I go “amber-hunting” at night ![]()
Any advice would be much appreciated. Or maybe someone knows where to find the parts I need to build a kick-ass UV searchlight ![]()
Cheers from Denmark
