Help! C8 problems
I just received a tangs fire c8 and Im having a problem. Wont stay on when I tighten the lens/reflector down all the way. Shorting out near led? I’m a noob so bear with me. If I loosen the lens(not head) it does turn on and function , any help would be greatly appreciated. Thank you.
Remove the reflector and see if there's anything sticking up that could touch the base of the reflector. Too much solder, a stray wire sticking up, insulator missing, etc.
Just figured it out, pill was loose in the head. Thanks, at least its good to know theres a place to ask questions. Its pretty bright, didnt know what to expect, the tints not too bad either, more warm than blue.
Add something( Anything) to make sure this isn't the case . I have some wicked tough tape I can pop a hole in and stick right over the bottom of the reflector . File down or snip away any solder blob sticking up or break out the soldering iron
I had a light a long time ago doing this and it flickered and sorta worked for about 3 minutes... till it just took out the driver . When torn down it was obvious what had happened . The aluminum reflector was touching both neg and pos. on the emitter .. without any isolator disk . Dumb since it could have been easily avoided
Could also be the led is loose and spinning when you tighten it and twists the emitter and wires .. just guessing now
muhahahaha! little do you know :wink: Welcome to BLF!
Bright is the easy part
